Formatted SD Card Recovery, How Much Can Realistically Be Saved?
I accidentally formatted my SD card and lost photos and videos I really need back. I stopped using the card right away, but I’m not sure how much data can actually be recovered after a format or what the safest recovery steps are. Looking for help with SD card data recovery, what to expect, and whether recovery software or a professional service is the better option.
I’ve been through this once with a drone card, and the short version is yes, your files are often still there after a format.
What usually happens is a quick format. Your camera, drone, or computer wipes the file index and marks the card as empty. The photos and video data often stay on the card until new footage lands on top of it. So the window for recovery is still open, but it closes fast.
The first thing I’d do is stop using the SD card right now. Take it out. Don’t record one more clip. Don’t copy anything onto it. Every new write raises the odds of overwriting the old data, and once chunks get replaced, recovery gets ugly or impossible.
If you want the best shot at pulling files back yourself, use recovery software. I had the best results with Disk Drill. What stood out for me was video recovery. Photo recovery is often easier. Video is where a lot of tools fall apart, esp if the card was used in a drone or action cam and the file got split into pieces across the card. Disk Drill includes an Advanced Camera Recovery mode for this kind of mess.
What I’d do, step by step:
  1. Put the SD card into your computer with a decent card reader. Don’t use a flaky one. Bad readers waste time and sometimes make the card disconnect mid-scan.
  2. Install Disk Drill on your computer’s internal drive. Keep the SD card untouched. Don’t install anything to it.
  3. Open the program, find the SD card in the device list, and run a scan. If the missing files are from a drone or camera, pick Advanced Camera Recovery.
  4. Wait for the scan to finish. Preview what it finds. I always check a few files before restoring, since a filename alone tells you nothing.
  5. Recover the files to your computer, not back to the SD card. Saving recovered data onto the same card is how people overwrite the stuff they were trying to save. Seen it happen.
If you want other routes, there are two people bring up a lot:
PhotoRec works, and it’s free. I’ve used it. It’s not friendly. The interface feels old, file names usually come back scrambled or generic, and folder structure is gone. Fine if you’ve got time and patience. Rough if you’ve got hundreds of clips.
R-Studio is serious software, but I wouldn’t hand it to someone who wants the easy path. It leans technical. Also, the free version won’t recover files over 1 MB, which makes it a bad fit for most video recovery jobs.
If the card won’t mount at all, keeps disconnecting, or holds footage you can’t replace, I’d stop the DIY part there. At that point, pro recovery shops are the safer move. They use hardware tools and chip-level methods regular users don’t have. It costs more, yeah, but many labs work on a no data, no charge basis, so you’re not always paying for a failed attempt.
So yes, recovery is still possible in a lot of formatted SD card cases. The big thing is speed and restraint. Stop using the card, scan it from a computer, and recover files somewhere else. That part matters more than people think.
Best odds depend on what kind of format happened.
Quick format on an SD card often leaves most raw data in place. Full format drops your chances a lot. If the card sat in a camera after formatting and you shot even 2 or 3 new videos, the loss jumps fast because video files are big and overwrite wide areas. Photos survive more often than long 4K clips. That part sucks, but it’s true.
I agree with @mikeappsreviewer on stopping use. I’d push one extra step first. Make a byte-for-byte image of the SD card before scanning. Work from the image, not the card. If the card has weak sectors or starts acting weird, you still get one clean shot. On Linux or Mac, ddrescue is solid. On Windows, some recovery apps do imaging too. Disk Drill is fine here because it lets you scan the card and recover to another drive, and it tends to do well with deleted photo and video sets.
One point I slightly disagree on. I would not jump straight into multiple deep scans with diffrent tools on the original card. Too much reconnecting, too much stress on cheap flash media.
Realistic expectation:
  1. Quick format, no new data written, card healthy. Often a high recovery rate.
  2. Quick format, some new data written. Mixed result.
  3. Full format or encrypted card. Recovery rate drops hard.
  4. Card errors, disconnects, unreadable size. Stop DIY.
Also, filenames and folders are often gone even when files come back. Don’t judge recovery by file names alone.
If you want more user experiences, this thread is worth reading:
formatted SD card recovery discussion for lost photos and videos
Realistic answer: if it was a quick format and you truly stopped using the card right away, recovery odds are often pretty decent. Not “100% no problem” decent, but way better than most people assume. Photos usually come back more often than big video files, esp if the videos were fragmented.
I mostly agree with @mikeappsreviewer and @cacadordeestrelas, but I’m a little less optimistic about “high recovery rate” as a blanket rule. SD cards are weirdly inconsistent. Two cards can get the same format and one gives back almost everything while the other returns a pile of broken clips and nameless JPGs. That’s just flash storage being annoying.
What matters most in your case:
  • Type of format
    • Quick format: best chance
    • Full format: much worse
    • In-camera format on some newer devices: can be worse than people expect
  • Whether TRIM/erase was triggered
    On some SD cards and adapters, deleted blocks may get actively cleared. If that happened, recovery drops hard. This is why some people do everything “right” and still get almost nothing back.
  • Card health
    If the card was already flaky before the format, don’t keep poking at it over and over.
My take on safest recovery path:
  1. If the files are extremely valuable, make an image of the card first.
  2. Recover from the image if possible.
  3. Use one solid tool first instead of shotgun-testing 5 apps.
  4. Save recovered files somewhere else only.
For software, Disk Drill is a reasonable first pick because it’s easy to use and handles photo/video recovery better than a lot of beginner tools. If you want to get a feel for it first, this Disk Drill review and recovery walkthrough is a decent overview.
One more thing people forget: recovered videos may exist but be unplayable until repaired. So don’t panic if a file comes back and VLC throws a fit.
If the card keeps disconnecting, shows wrong capacity, or asks to be formatted again, I’d stop DIY there. That’s where people turn a recoverable mess into a total one by being stuborn.
Realistically, formatted SD card recovery can range from “almost everything” to “barely anything,” and a lot of that depends on one annoying detail people skip over: what device did the format. I slightly disagree with the blanket idea that quick format always means high recovery. On some cameras, drones, and phones, the “format” process is more aggressive than the label suggests.
A few things I’d add to what @cacadordeestrelas, @jeff, and @mikeappsreviewer already covered:
  • Small photos usually recover cleaner than large videos
  • Recovered file count is not the same as usable recovery
  • A card can look healthy and still return corrupted video chunks
What I’d watch for first is whether the recovered previews actually open fully. If a tool finds 2,000 files but half the videos freeze after 3 seconds, that is not a great result.
About Disk Drill: it’s a reasonable first DIY option because it’s easy to navigate and it handles common photo and video formats well.
Pros
  • simple interface
  • good preview support
  • decent with SD card photo/video recovery
  • can be less intimidating than forensic-style tools
Cons
  • not magic if data was overwritten or trimmed
  • deep scans can return messy filenames
  • large video recovery may still come back partially damaged
  • paid recovery limits matter depending on version
My view: use one good tool first, check previews, and judge by file integrity, not just file totals. If the card now shows odd size, slow reads, or random disconnects, stop experimenting. That is when DIY recovery starts getting worse, not better.
