I tried keeping a spreadsheet and adding renewal reminders to my calendar for the subscriptions I manage for my work team. When I checked our recent charges, I still found an active subscription that was missing from both places and that nobody on the team remembered using. I expected the calendar to be enough, but it only works when I remember to enter everything. How do you remember which subscriptions you’re paying for, and do others run into the same gaps?
Do not rely on the calendar as the source of truth. It only contains subscriptions that a person remembered to enter, and it will always miss the purchases made on a different card, an app store, PayPal, or an employee’s expense account.
Instead, it is better to start from the money: go over all the company cards and accounts paying for subscriptions and compile a single list of your subscriptions with information on the vendor, the amount, billing frequency, payment method, owner, next payment date, and cancellation procedure. Then reconcile this list with the statements to ensure that nothing is paid twice or not cancelled when it should be. Doing this every month or quarter is more efficient than updating the spreadsheet every time someone buys something.
I would also add a field “owner” to this spreadsheet and make sure that the person who has this subscription is marked as such. The owner will be responsible for reviewing the subscription every year to renew or cancel it based on whether they still need it. “Marketing team” is not a valid owner; a specific person should take responsibility and be able to justify the subscription. If nobody claims ownership, it should be suspended or cancelled after checking that it does not contain any critical data.
Annual subscriptions and charges paid under the umbrella of the parent company are often the ones that get missed in between. This practice should be reviewed yearly to check if any subscriptions have been missed in the statements. A shared purchase card or a shared approval for new subscriptions might be a solution for this problem, but it might require auditing app-store subscriptions and expense reimbursements claims on a quarterly basis.
The spreadsheet isn’t the main problem. Decentralized purchasing is. If renewal notices and receipts go to individual employees, your records will fall apart whenever someone changes roles or leaves.
@byteloop5388sync is right that statements expose forgotten charges, but they only catch them after money moves. Route every subscription’s billing email to a shared finance inbox and require a team-owned login or admin account. That inbox becomes an early-warning system for renewals, price changes, failed payments, and trial conversions.
For tighter control, assign each service its own virtual card or card label. You can immediately identify an unclear charge and disable that vendor without replacing the payment method for everything else. The goal is to stop relying on people remembering to update a document.
A company shared mailbox cannot provide an extensive list of subscriptions because some of them can be paid through app stores, PayPal, reimbursement claims, or an employee’s charge card. This way, the invoicing email address would not be associated with the finance department.
To begin with, it is essential to conduct one comprehensive audit of all the sources paying for subscriptions and compile a list of all the services with their owners, who are responsible for their cancellation or renewal. It is critical to note each paid month or year, as well as the person who has access to this account. Each subscription should have a “decision date” – the moment when the owner determines whether it should be renewed, cancelled, or moved to another person in charge, instead of a generic “remind me every year.” The audit should cover all the expenses from the last yearly cycle or more, depending on the billing periods of the services.
Once the complete list of subscriptions is compiled, it should be reviewed on a regular basis by the owners to ensure that everyone still uses the tools they have paid for. In addition, if nobody claims a particular service, it should be cut off or frozen. This way, the automatic renewal of subscriptions that nobody requested will become an exceptional case, not the norm.
The hidden tax on sorting this out is that the “unused” sub is frequently the one that has an integration nobody owns but runs through it. No recent logins do not equal no usage; it might be doing something annoyingly necessary like walking forms or storing backups or touching a domain renewal or sitting as an old client facing site or even providing an API key embedded somewhere in a process.
You’ll learn what it does, five minutes after canceling.
I’d rather move questionable subs into a cancellation queue, post a note with the vendor, contact email for the account, what purpose it may have served, and a proposed cut-off date visible to everybody, than kill them. Trim the seats or lower the tier if possible, and give it a while to see if some distant team member will realize this is part of their ecosystem and hasn’t been documented anywhere.
The suggested owner requirement is valuable, but I would not take “unclaimed” to mean “canceled.” First, find if there are any logs showing what it was used for - connected apps, API calls, files stored or exported, reports run, things it might be responsible for hosting (a domain or an app) or if they’re going to have to call and ask nicely because the thing is deeply entangled in a system that doesn’t make easy exports. Keep an invoice saved in case an angry phone call erupts, and don’t forget to export any data before shutting it down; they cancel quickly, but some companies fight harder to keep customers than they let customers keep their data.
Once you’ve got questionable subs sorted, I’d bin the rest using the criteria “if this renewal failed, how much trouble would we actually be in?” and sort them into “nuisance” and “team emergency” to prioritize future reviews. Some companies will renew that $12 tool and throw it a five-alarm funeral if it ever stops working, while other “indispensable” software licenses can be quietly dropped into the spreadsheet and revisited when budget allows.
A forgotten design tool is annoying, but abandoned cloud account with usage billing can become really expensive with no date of renewal at all.
Separate your metered services from the subscription ones: record the owner of the cloud hosting, messaging API, advertising platforms or other accounts and set spending alerts or limits inside the service. Any calendar reminder about paying is useless if your bill depends on traffic, storage, or some forgotten script.
That leaves you with two options for everything that is not a billed subscription - reviewing renewals and spending tracking for anything variable. And treating them as different things is why stranger charges keep winning.
Take the last several statements and underline every charge that you cannot name immediately and then email them to the finance inbox address on file for each. The response you get back will tell you if it’s a live tool with an owner or a ghost. It’s a cheaper investment than making the perfect register before you’ve identified what is real.
The thing nobody here mentioned is that cancelling isn’t the same as being cancelled. I’ve seen plenty of cases where someone hits the button, gets a cheerful ‘we’re sorry to see you go’ page, and the card still gets hit next cycle because the account only downgraded or the cancellation didn’t take. Screenshot the confirmation, save the email, and check the following statement. If the charge reappears, you now have proof for a dispute instead of arguing from memory. @danthewizard’s point about exporting data first is spot on, but add ‘verify the charge actually stopped’ to that checklist.
I’d also gently push back on the register worship in the earlier replies. A spreadsheet with fifteen columns per row is great until the person maintaining it gets busy, and then it rots exactly like the calendar did. Track the boring fixed subscriptions loosely and spend your real attention on two things: anything metered, which @retro_hawk225 already flagged, and free trials that quietly flip to paid. Trials are the sneakiest because there’s no ‘renewal’ to review, just a first charge that shows up looking like it was always there.
A charge using the product name is simple to identify, whereas, one that is billed under a parent company or payment processor may appear unrelated. I would retain the exact description of the statement alongside the service name to prevent mysterious charges from appearing on my statement.
