Need Help To Recover Deleted Files From Hard Drive
I accidentally deleted important files from my hard drive and realized too late that I don’t have a backup. I’m looking for help with hard drive file recovery, including the best recovery software or steps to avoid making things worse. These documents and photos are really important, and I need advice on the safest way to try to get them back.
Take a breath first. I know the stomach-drop feeling when files vanish. Still, on a hard drive, deleted does not always mean erased. If you move fast and keep your hands off the drive, your odds are decent.
Stop using the drive right away
This part matters more than anything else. The moment I notice files are gone, I stop saving, downloading, browsing, all of it. If the missing stuff lived on your main system drive, even normal web use adds writes in the background.
What I learned the hard way is simple. When you delete a file, Windows or macOS usually marks the space as free. The old data often stays there until something new lands on top of it. So every new write is a risk. If you keep using the disk, you raise the chance of wiping out the same file you want back.
So, yeah, stop using the drive. Completely.
Figure out which drive you lost files from
  1. External drive or secondary internal drive
    Best case. Unplug it and connect it to another computer. Scan it there, where you are not adding fresh data to the same disk.
  2. Main OS drive
    This one gets messy fast. I would boot from a USB stick or connect the drive to a second machine. The goal is the same, avoid writing new data to the drive while you try recovery.
Run recovery software, and do not install it to the same drive
If you caught the deletion early, software recovery is where most people get results. I have tried a few tools over the years, and the one I kept going back to was Disk Drill.
What stood out for me, it digs past recently deleted stuff and often finds files buried deeper in the file system mess. The preview feature helps too. You get to check whether the file still opens before restoring it, which saves a lot of false hope. The free version scans and previews, then payment only comes up if you want to recover.
The part people mess up, install the software to a different drive. Not the one you are scanning. I did this wrong once, years ago. Bad idea. You do not want the recovery app writing over the data you are trying to save.
Stuff worth knowing before you start
  1. Hard drives usually give you a better shot than SSDs
    Old-school HDDs tend to be kinder for recovery. SSDs are less forgiving. Also, some newer hard drives support TRIM, so I would not sit on this for hours thinking the files will wait around forever.
  2. If the drive clicks or grinds, stop
    Software is not fixing physical damage. If you hear clicking, scraping, or grinding, you are past DIY territory. That is a job for a recovery lab.
  3. Do one solid scan, not ten random ones
    Running scan after scan usually wastes time. One thorough pass is often enough. After tht, save recovered files somewhere else and review what you got.
If you move quickly and keep things careful, you have a fair shot at getting your files back. I would stay calm, work in order, and avoid touching the original drive more than needed.
I’d add one step before you run any scan, make a sector-by-sector image of the drive if the files matter a lot. @mikeappsreviewer is right about stopping use, but I don’t love scanning the original disk first if you have enough free space on another drive.
Use something like ddrescue on Linux, or R-Studio’s imaging tool on Windows. Work from the image, not the source. If a scan goes bad, or the drive starts degrading, you still have one clean shot left. Labs do this for a reason.
For software, Disk Drill is fine for simple deletes and it’s easy to use. If Disk Drill misses stuff, try Recuva for recent deletions or PhotoRec if you only care about file content and folder names do not matter. PhotoRec is ugly, but it pulls data from damaged file systems better than a lot of polished apps.
Couple more things people skip:
  1. Check cloud sync trash. OneDrive, Google Drive, Dropbox.
  2. Check file history, shadow copies, Time Machine snapshots.
  3. Sort recovered files by type and date first. Saves time.
  4. Recover to a different drive, always. People still mess this up.
If the drive shows SMART errors, slow reads, or freezes Explorer, stop doing random scans. Clone first. Time matters more thn speed here.
Also, if you want a quick visual guide, this hard drive recovery tips for deleted files reel is easy to skim.
One thing I’d push that @mikeappsreviewer and @caminantenocturno only touched on indirectly: figure out how the files were deleted before you start throwing tools at it. If it was a normal delete, check the Recycle Bin plus any app-specific trash first. A lot of programs keep their own temp/export folders, and people forget that. If the files were cut during a move and vanished, search by file extension across the whole drive before assuming they’re gone.
Also, don’t judge recovery software by the first scan result list. File names can look perfect and still be corrupt, or look mangled and still recover fine. That’s why Disk Drill is useful, not just because it scans well, but because previewing recoverable files saves a lot of wasted time. I don’t totally agree with the “one scan is enough” idea in every case either. Sometimes a quick scan misses what a deeper pass finds, esp on messy file systems.
Another tip: if the data matters for work, photos, taxes, legal docs, whatever, write down the folder names, file names, and approximate dates before you begin. Sounds dumb, but once you’re staring at 40,000 recovered files named FILE0001.jpg, your brain turns to soup.
If Windows still sees the drive normally, run a SMART check first with CrystalDiskInfo or similar. If health is bad, stop DIY stuff and image/clone before doing much else.
And for anyone researching this stuff, this external hard drive file recovery tips and discussion post is pretty relevant too.
One extra angle: check whether the deletion was local or just a view problem. I’ve seen “deleted” files turn out to be hidden by a bad filter, wrong user profile, corrupted library, or a changed drive letter. Before recovery, search the whole disk by exact filename and extension from another machine if possible.
I slightly disagree with the “do one solid scan only” idea as a blanket rule. On a healthy drive, a fast pass and then a deep pass can make sense. Different methods find different things.
On Disk Drill specifically:
Pros
  • very easy preview workflow
  • good for normal deletes and formatted partitions
  • decent file type sorting, which helps with big recoveries
Cons
  • deeper scans can return lots of raw files with messy names
  • paid recovery can feel pricey for one-time use
  • not my first pick if the drive is physically unstable
If Disk Drill doesn’t get it, test results against Recuva, R-Studio, or PhotoRec before giving up. And yeah, the points from @caminantenocturno, @nachtschatten, and @mikeappsreviewer about avoiding writes are the part people ignore right before they make it worse.
