When I need to prepare a photo for an upload form, the file-size restriction is what makes me look for an alternative to a full photo editor. I want a smaller copy that meets the requirements without losing the details someone needs to see.
Decide what the finished image needs to preserve
I would check the form’s requirements before changing anything. A limit on file size is not the same as a requirement for pixel dimensions, and satisfying one does not necessarily satisfy the other. That distinction matters if you are considering reducing the image’s width to save space.
The type of image matters, too. An ordinary photograph and a logo with a transparent background need different checks. PNG input can become JPEG output with this compressor, so I would not assume that transparency will survive. If the background needs to remain transparent, checking the downloaded format belongs on the list alongside checking its size.
I would also decide how the picture will actually be viewed. That gives me a more useful way to judge the result than simply looking at how much smaller the file became. Faces, fine edges, and small lettering are worth inspecting at the intended viewing size. A download that meets the upload limit but makes important text difficult to read is not the result I am after.
Before doing any of that, I would keep the original separate. The compressed version is the upload copy, not a replacement for the source image.
Use the size limit first, then adjust if needed
For the compression step, the CleverHumanizer tool accepts JPG, PNG, and WEBP files and lets you choose either a quality setting or a target file size. It is free, requires no signup, and adds no watermark. Processing happens in the browser rather than sending the photos to a server.
For a form capped at 200 KB, I would choose “Fit a size limit” and enter that allowance. That is more direct than repeatedly changing quality and checking the download. With a strict 1 MB allowance, I would aim a little below the boundary rather than try to land exactly on it.
If the result still needs to shrink, the maximum-width setting is worth checking before lowering quality further. Removing resolution you do not need can make more sense than applying increasingly harsh compression to a large picture. Any required dimensions still take priority.
Batch processing is available, but I would try a detailed image first and inspect the result before applying the same settings to the rest. That keeps the workflow simple without treating every picture as though it has the same needs.
Which tends to cause more trouble with your uploads: the size cap, required dimensions, or keeping details readable?
