What's The Easiest Way To Restore A Formatted Thumb Drive?
I accidentally formatted my USB thumb drive and lost important files I still need for work. I’m looking for the easiest and safest way to recover data from a formatted flash drive before anything gets overwritten.
I did this once with a USB full of photos and PDFs, and the first thing I learned was simple. A format is bad, but it does not always wipe everything out. What matters most is which format was used and whether anything was written to the drive after.
If the drive got a Quick Format, recovery odds are often decent. That option usually finishes fast because it rebuilds the file system and drops the old index. The files themselves often stay on the storage until new data lands on top of them. A Full Format is a different mess. It tends to overwrite the drive, so software recovery often comes up empty.
First move, stop touching the USB. I mean it. Do not copy files onto it. Do not format it again. Do not run CHKDSK or other repair tools. Every extra write lowers your odds. Once old data gets overwritten, it is usually done.
Before trying recovery tools, I would check for copies you forgot about. People miss this step all the time. Look here:
  1. OneDrive, Google Drive, Dropbox, or iCloud.
  2. Windows File History or Backup and Restore.
  3. Another external drive or an older flash drive.
  4. Your PC folders like Downloads, Desktop, and Documents, if the files started there.
  5. Email attachments or chat apps where you sent the files before.
If none of those turns up anything, I would move to recovery software. For a formatted flash drive, that is usually the next sensible step.
I’ve used Disk Drill, and it was one of the easier ones to work with. My steps were:
  1. Install Disk Drill on your computer’s internal drive, not on the formatted USB.
  2. Plug in the flash drive.
  3. Open Disk Drill and pick the USB from the device list.
  4. Click Search for Lost Data, then choose Universal Scan if it asks. For formatted drives, I’d start there.
  5. Let the scan run to the end. I know, it feels slow. Still worth waiting because more files often show up later in the scan.
  6. Preview whatever you want back. If a photo opens or a document previews cleanly, I’d take that as a good sign.
  7. Recover everything to a different drive. Do not save recovered files back onto the same USB.
One thing I liked, it sorts results into groups like Photos, Videos, Documents, Audio, and Archives. You can also filter by extension, file type, size, and recovery likelihood. If the folder names are trashed or filenames came back weird, those filters save time.
If the flash drive keeps disconnecting, throws read errors, or crawls at a painfully slow speed, I would not keep scanning the original device over and over. I’d use Disk Drill’s disk image option first. It makes a full copy of the USB, and you scan the copy instead. Safer if the hardware is starting to fail. I learned this one a bit too late, tbh.
If the scan finds less than you hoped, do not write it off right away. Go back to the type of format used. Quick format often leaves more behind. Full format usually leaves less. If you have no clue which one happened, I’d still run the scan. You do not know what survived until you look.
I’ve seen people get their files back from formatted flash drives more often than you’d think. So yeah, there is still a shot. Keep the USB untouched while you try recovery. If the files matter a lot, like work records or family photos, and software gets nowhere, the next step is a professional recovery service. They have tools for cases where home recovery hits a wall.
Best move is to treat the thumb drive like evidence. Stop using it. Unplug it. Every new write cuts recovery odds.
I agree with @mikeappsreviewer on the big part, don’t write anything to the USB. I differ a bit on one point though. People spend too long guessing quick format vs full format. If the files matter for work, I’d skip the guessing and do one safe pass with recovery software right away.
My easy route:
  1. Plug the USB into a stable PC, no hubs if possble.
  2. Check Disk Management first. If the drive shows the right size, that’s a good sign.
  3. If it mounts, run Disk Drill and scan the whole device, not a folder.
  4. If it acts flaky, make a byte-for-byte image first, then scan the image.
  5. Recover files to your PC or another external drive, never back to the thumb drive.
Why Disk Drill here? It’s simple, and it does well with formatted USB recovery, photos, Office docs, PDFs, ZIPs. Preview matters. If your DOCX or XLSX previews cleanly, odds are better the file is usable.
One more thing people miss. USB flash storage uses wear leveling. Sometimes even a format plus light reuse does not kill every file, and sometimes one small copy job kills the exact file you need. So move fast.
If you want a plain guide on recover data from a formatted USB drive, this short explainer helps: watch how to recover files from a formatted USB drive
If Disk Drill finds nothing and the files are important, stop there. Repeated scans are usless on a dying stick. At that point, pro recovery is the safer next step.
Biggest thing: do not “restore” the thumb drive first. A lot of people click repair/format again and basically make it worse.
I mostly agree with @mikeappsreviewer and @shizuka, but I’d push one extra step before scanning: if the files are really job-critical, clone or image the USB first if your system can still read it. Not everyone bothers, but flash drives can go weird fast, and one bad reconnect later you’re stuck. If the drive is stable, then sure, scan it directly.
Also, small disagreement with the “check format type too much” angle. It matters, but for most normal users the practical question is simpler: was anything copied onto it after formatting? If yes, recovery odds drop. If no, you still have a decent shot.
What I’d do:
  1. Unplug the USB and stop using it.
  2. Plug it into a main USB port on a desktop/laptop, not some crusty hub.
  3. If it opens normally or at least shows the right capacity, run Disk Drill.
  4. Scan the whole device, not just the visible partition.
  5. Recover files to your PC or another drive, never back onto the same stick.
Why Disk Drill? Mostly because it’s easy and doesn’t make you fight with a bunch of nerdy menus. For formatted USB recovery, that matters. If previews work for your docs/photos, that’s a solid sign the files are actually usable and not just ghost entries.
One more thing people forget: if Word or Excel files are super important, try recovering older temp/backup copies from the work PC too. Office autosaves, temp folders, email attachments, Teams/Slack uploads, all that boring stuff sometimes saves your butt.
If you want extra reading before using it, this real-world Disk Drill review for USB data recovery is probly more useful than random marketing pages.
If the flash drive starts disconnecting, shows 0 bytes, or makes Windows freeze, stop messing with it. That’s when DIY turns into “whoops, now it’s worse.” At that point, pro recovery is the safer move.
Small pushback on the “just scan it” advice from @shizuka, @caminantenocturno, and @mikeappsreviewer: if this is work-critical and the USB is even slightly flaky, I’d spend 5 extra minutes checking SMART-like behavior isn’t really possible on most thumb drives, so your best clue is simple stability. If it disconnects once, image first or stop.
My take: the easiest safe path is recover the files, not the drive. Don’t try Windows repair, don’t reformat again, don’t use “restore previous version” on the USB itself.
Disk Drill is a reasonable choice here because it keeps the process simple.
Pros
  • Easy interface
  • Good file previews
  • Handles formatted USB scans well
  • Can scan the whole device, not just the visible file system
Cons
  • Deep scans can return messy filenames
  • Free recovery limits depend on platform/version
  • Not magic if data was overwritten
One extra thing I’d add: after recovery, open a few restored Office files before calling it done. Formatted-drive recovery can bring back files that exist but are corrupted internally. Preview is helpful, but real-open testing matters more. If the first batch is bad, try recovering by file signature/type instead of folder structure. That sometimes gets cleaner results on flash media.
