A realistic expectation is that no checker will save you much time once a score is challenged. The percentage may take seconds to produce, but explaining what it means to a student, parent, or administrator can turn into a much bigger job. If the tool cannot show a repeatable method and your school has no written process for handling results, I would be very cautious about putting the score in a grade record.
I would push back slightly on the idea that agreement between two detectors makes a case stronger. Two tools can agree because they react to the same features, such as predictable structure, formal wording, or low variation in sentence patterns. That is not independent confirmation that AI was used. If they disagree, you learn that the result is shaky. If they agree, you still have only two automated guesses.
The useful test is whether a checker improves your review process without deciding the outcome. Before using one on questionable submissions, run it on a small set of work whose history you already know: essays written under supervision, early drafts, revised versions, and some of your own assignment materials. You are not trying to calculate a universal accuracy rate. You are checking how often the tool produces results that would waste your time or unfairly put a student under suspicion.
I would set a procedure before looking at any score. A flag might lead you to compare the essay with an in-class sample, inspect document history, check whether sources support the claims, and ask the student to explain a paragraph or reproduce part of the reasoning. Avoid making the student prove a negative based only on wording that “sounds like AI.” A student who used a tutor, grammar software, a translation tool, or extensive teacher feedback may have a polished final draft that differs sharply from earlier work without having submitted an AI-written essay.
@primecraft5689edge’s privacy warning matters here, but retention is only part of the problem. You should know whether uploaded work may be used for system improvement, who can access reports, how long records remain available, and whether the tool’s output is stable enough to review later. If a disciplinary decision could depend on it, a disappearing dashboard score or an unexplained percentage is a poor record.
So my answer is that the “best” checker is the one your school permits and that creates the least misleading report, but I would not select any of them as an enforcement tool. Your observed drafts are better evidence. The detector’s proper role is to point you toward a closer look, and sometimes the correct response to a flag will simply be to ignore it.
