I’m trying to pick the best AI image generator for design, social media, and some light client work, but the options are overwhelming and most reviews feel biased or out of date. I’ve tried a few free trials, but I’m still not sure which tools are really worth paying for in terms of quality, speed, copyright safety, and commercial use. Can anyone share up-to-date, real-world experiences comparing the top AI image generators and recommend which ones are truly worth using?
I went through this rabbit hole for social posts, web design mockups, and some client ads. Short version, use more than one tool. No single “best”.
Here is what has worked for me.
- Midjourney
• Best for: Pretty stuff, concept art, cool social media visuals.
• Strengths:
- Great composition and lighting.
- Good at logos as mood concepts, not final logos.
- Huge Discord community for prompt ideas.
• Weak points: - No native web app. All inside Discord.
- Harder to do consistent brand characters.
• Pricing: About 10 to 30 USD per month depending on plan.
• When I use it: Hero images for landing pages. Backgrounds. Stylized social posts.
- DALL·E 3 (inside ChatGPT / Bing Image Creator)
• Best for: Fast drafts, social images with text, more literal prompts.
• Strengths:
- Handles written text in images better than most.
- Good for “I need this idea in 1 minute”.
- Works well with natural language prompts.
• Weak points: - Quality lower than Midjourney and SD XL for detail.
- Less control over fine style.
• Pricing: - Bing: free with limits.
- ChatGPT Plus: 20 USD per month, images included.
• When I use it: Quick social graphics with readable text. Client mockups in a hurry.
- Stable Diffusion XL (through tools like Leonardo, ComfyUI, Automatic1111)
• Best for: Control, workflows, brand consistency, “serious” design work.
• Strengths:
- You control models, upscaling, styles.
- Good for product shots, consistent characters, variations.
- Good privacy if you run it local.
• Weak points: - Setup takes time.
- You need some technical patience.
• Pricing: - Model is free.
- You might pay for GPU, or use sites like Leonardo, Mage, etc.
• When I use it: Anything for client stuff where I need the same style every time. Ecom-style images. Ad concepts.
- Adobe Firefly / Photoshop Generative Fill
• Best for: Real client work inside the Adobe stack.
• Strengths:
- Good for photo editing, extensions, cleanups.
- Safe content filters help with client comfort.
- Works smoothly with PSD files and layers.
• Weak points: - Prompted generation alone is not as strong as Midjourney or SD XL.
• Pricing: - Bundled with Photoshop plans.
• When I use it: Retouching, extending backgrounds, fast layout fixes. Turning AI output into real deliverables.
- Canva AI / “Magic Media”
• Best for: Social media users who live inside Canva.
• Strengths:
- Integrated with templates, text, brand kits.
- One place to do the entire social post.
• Weak points: - Quality lower than dedicated image models.
• Pricing: - Included in Canva Pro.
• When I use it: Quick posts for small clients, low budget, low expectations. Good enough for IG carousels and stories.
If I were you and doing design, social, and light client work, I would set it up like this:
• For daily social content
- Canva or DALL·E 3 for speed.
- Midjourney when you need “wow” images.
• For design mockups and hero sections
- Midjourney for main visuals.
- Then polish in Photoshop with Generative Fill.
• For client work that needs consistency
- Stable Diffusion XL using a hosted service like Leonardo or DreamStudio.
- Train a LoRA or style on your brand or client look.
- Use Photoshop or Figma for final layout.
Try this workflow for a week:
- Start drafts in DALL·E 3 or Midjourney.
- Take the best ones into Photoshop. Clean with Generative Fill.
- For clients that come back often, move to SD XL for repeatable style.
You do not need all of these paid at once. A realistic cheap stack:
• ChatGPT Plus or Bing for DALL·E 3.
• One paid Midjourney month when you batch work.
• Free or cheap SD XL host such as Leonardo for testing.
• Existing Adobe or Canva sub if you already use it.
If you share what exact type of client work you do, I can narrow this down even more.
You’re not crazy, this space changes every 3 weeks and half the “reviews” are just affiliate funnels.
I mostly agree with @cazadordeestrellas on using multiple tools, but I’d tweak the stack and priorities a bit, especially for client work and social.
1. Start from what actually matters to you
Instead of “best tool,” ask:
- Do you need brand consistency across weeks/months?
- Do you need real control over layout, text, aspect ratios?
- Do you care about license / usage terms for paid client projects?
- How much time do you want to spend learning vs shipping?
Your answers to those matter more than which model is “prettier.”
2. Where I slightly disagree with the earlier breakdown
- Midjourney is gorgeous, yes, but for client work it can be a pain:
- Aspect ratios are still kinda annoying for specific formats.
- Revisions in a specific direction can get fiddly.
- For social, it can over-style things when you just wanted simple and clean.
If you are doing “light” client work rather than concept art, I’d put more weight on tools that sit inside a layout or design environment.
3. What’s actually worth your time right now (for your use case)
You said: design, social, light client work. I’d build around 3 cores:
Core A: Layout-centric tools
Use something where images + text + brand stuff live together.
Figma + plugins (like Microsoft’s Designer / various AI image plugins)
- Good for: web mockups, ad concepts, layout-first design.
- Why: You think in frames, grids, hierarchy instead of random single images.
- Use: Generate a base image, then tweak composition, overlay text, build variations quickly.
Canva actually deserves more credit here than people give it:
- Yes, quality is worse than Midjourney.
- But for social, the “whole post” matters more than pixel-perfect rendering.
- For small clients, it’s fast, and speed often beats “artistic quality.”
If you do recurring social content, I’d honestly start here, then swap in higher quality images from other tools when needed.
Core B: High quality image engine
You basically want one “big gun” model.
If I had to pick one today for mixed work:
- Stable Diffusion XL on a hosted service
- Why:
- Actual control over seeds, versions, LoRAs, etc.
- You can get consistent characters and brand-ish looks.
- Easier to scale a style when a client suddenly wants 30 more variations.
- Downside: learning curve, like @cazadordeestrellas said.
- Upside: once you get comfy with a host like Leonardo / Clipdrop / DreamStudio, it becomes your “reliable workhorse.”
- Why:
I’d put SDXL above Midjourney for client work specifically, because control and repeatability matter more than the default “wow” factor.
Core C: “Get it done in 60 seconds” tool
You absolutely want one lazy tool for “post is due in 5 minutes” days:
- DALL·E 3 (via Bing or ChatGPT)
- I agree here: text in images is a big advantage.
- Also, the prompts can be very plain english.
- Perfect for idea drafts and quick social filler content.
I wouldn’t rely on it as your main design engine, but as a sketchpad and speed booster it’s great.
4. Tools I’d treat as optional, not must-haves
Midjourney
- Amazing for “wow” imagery, moodboards, and concept art.
- I’d get a one month sub when you have a specific batch project: new portfolio, a big campaign, a bunch of hero headers.
- I wouldn’t keep it as a permanent sub if you’re on a budget and mostly doing functional design + social.
Adobe Firefly / Photoshop generative
- Great if you already live in Adobe.
- I wouldn’t get an Adobe sub purely for Firefly if you’re light on client work.
- The power is in editing and extending, not in raw idea generation.
5. A simple, realistic setup
If I had to keep it lean and practical for your situation:
Primary layout & publishing:
- Canva or Figma (whichever fits your brain better).
Main image generator for “real” work:
- SDXL on a hosted platform (Leonardo or similar).
- Learn:
- basic prompting
- how to use seeds
- how to save styles / presets for each client
Emergency draft tool:
- DALL·E 3 through Bing or ChatGPT.
Optional burst months:
- Midjourney for high-impact hero images when you know you’ll really use it.
6. How to actually test without going insane
Instead of random free trials, do this:
- Pick one real deliverable:
- e.g. “Instagram carousel + matching website hero for X client”
- Try to build the exact same deliverable in:
- Canva or Figma + DALL·E
- Canva or Figma + SDXL host
- (Optionally) same thing with Midjourney
- Time yourself and note:
- Total time from idea to something you’d actually send a client
- How easy revisions were
- How easy it would be to make the same thing again next week
Whichever stack makes that test feel smooth is your winner, regardless of what any review says.
If you share what kind of clients you have (local businesses, coaches, SaaS, ecommerce, etc) and which tools you already pay for (Adobe, Canva, Figma), you can narrow it down to basically 2 primaries + 1 backup and not think about it again every month.
