Can anyone help me understand Hcs 411gits error codes?
I’m running into Hcs 411gits error codes and can’t figure out what they mean or how to fix them. The issue started while I was trying to complete a setup, and now the process keeps failing. I need help understanding these error codes, what causes them, and the best steps to troubleshoot the problem.
HCS error codes are vague unless you know what product or service is throwing them. ‘411gits’ does not look like a standard Windows HCS code by itself. It sounds like one of these:
  1. A vendor-specific installer code.
  2. A typo in the log name or package name.
  3. A Hyper-V or Host Compute Service error wrapped by another app.
Start with the simple checks.
  1. Find the full error text.
    Look in the install window, event viewer, or setup log. You need the exact code and message, not only ‘411gits’. If you post the full line, people can narrow it down fast.
  2. Check logs.
    On Windows, look here:
    C:\Windows\Logs
    C:\ProgramData
    Event Viewer, Windows Logs, Application
    Event Viewer, Applications and Services Logs, Microsoft, Windows, Hyper-V-Compute
  3. Rule out common setup failures.
    These cause a lot of setup breaks:
  • bad installer download
  • no admin rights
  • antivirus blocking files
  • missing .NET or Visual C++ runtime
  • low disk space
  • pending reboot
  1. Run these checks.
    Open Command Prompt as admin:
    sfc /scannow
    DISM /Online /Cleanup-Image /RestoreHealth
If HCS means Host Compute Service, also check:
sc query vmcompute
If it is stopped, start it:
net start vmcompute
  1. If this started during setup, do a clean retry.
  • reboot
  • disable antivirus for the install
  • re-download the installer
  • run as administrator
  • install from a short path like C:\Install
If you want a real answer, post:
  • full error code and message
  • app name
  • Windows version
  • screenshot or log snippet
  • what step fails
Right now, ‘Hcs 411gits’ is too broad to map cleanly. Feels like a log typo tbh.
I’d actually push back a little on @jeff here. Sometimes the weird-looking code is not the real error at all, it’s just a fragment from a package name, script label, or internal module, so chasing “411gits” by itself can waste a ton of time.
What I’d check instead:
  • Does the setup create a rollback log or temp folder right before it fails? A lot of installers dump the real failure there.
  • If this is in a command window or script, look for the line before the code. The parent error is often one line up.
  • Try installing with a clean boot. Not just antivirus off, but non-Microsoft startup stuff disabled too. Background services break setups more than ppl think.
  • If it’s tied to containers, WSL, Docker, or Hyper-V, make sure virtualization is enabled in BIOS/UEFI. That one gets missed allll the time.
  • If the installer supports verbose logging, use it. MSI example:
    msiexec /i package.msi /L*v install.log
Also, “gits” makes me wonder if it’s related to Git, a plugin, or even a badly parsed string, not an HCS code at all. That’s why the exact wording matters.
Post:
  • exact app/setup name
  • full error text
  • whether this is MSI, EXE, Docker, WSL, Hyper-V, etc.
  • last 10 lines of the log
Without that, everybody’s kinda guessing tbh.
I’d split this into two possibilities, because “HCS” usually points to Host Compute Service on Windows, but 411gits does not look like a standard HCS code to me. That’s where I slightly differ from @jeff. I would not start by decoding the number first. I’d start by proving whether the failure is actually coming from HCS at all.
Quick way to narrow it down:
  1. Open Event Viewer
    • Applications and Services Logs > Microsoft > Windows > Host-Compute-Service
    • Also check Hyper-V-Compute, Hyper-V-Hypervisor, and Containers
  2. Check Windows Features
    Make sure the right combo is enabled:
    • Hyper-V
    • Virtual Machine Platform
    • Windows Hypervisor Platform
    • Containers
    • WSL, if relevant
  3. Run these commands
    systeminfo
    Look near the bottom for Hyper-V requirements.
    dism /online /get-features /format:table
  4. Look for corruption
    sfc /scannow
  5. If this started after an update
    Check for:
    • pending reboot
    • broken KB install
    • device guard / core isolation conflicts
If this is Docker or WSL related, resetting the distro or Docker backend can help more than chasing the code text.
For ':
  • Pros: readable, easier to scan notes/log steps if you’re documenting fixes
  • Cons: not useful unless you already have the exact log source
Post the exact error line and what setup is failing. That will tell a lot more than “411gits” by itself.
