Clean Up App User Review – Does It Work As Advertised?
I’ve been using the Clean Up app to declutter my photos and files, but I’m not sure it’s working the way it’s advertised. Some duplicates seem to stay, and I’m worried it might delete important stuff by mistake. Can anyone share real experiences or tips so I can decide if it’s safe and worth keeping?
Cleanup App (Phone Storage Cleaner) – my experience vs Clever Cleaner
Cleanup App (Phone Storage Cleaner) review
My iPhone hit that point where every new photo triggered the “storage almost full” popup. I use iCloud, but I still keep a lot of stuff local, so I went hunting for a cleaner app and ended up trying Cleanup App (Phone Storage Cleaner).
On paper it looked decent. It scans:
  • Duplicate photos
  • Similar looking photos
  • Screenshots
  • Big videos
  • Contacts with duplicates or missing info
It also offers video compression and some “extra” bits like animations and a secret vault.
The scan itself worked. It did find clusters of similar photos and a pile of old screenshots I forgot about. The problem started when I tried to do something with the results.
Most actions were subscription locked. The free version mostly turns into a demo:
  • You see the junk, but bulk cleanup is paywalled
  • To use some actions without paying, you sit through a lot of ads
  • The ad frequency made it slower than using the built‑in Photos cleanup tools
The “fun” features like animations and the secret vault felt out of place for a storage cleaner. Looked more like they padded the app than focused on the main job, which is freeing space quickly.
What other users say about Cleanup App
This part matched what I saw in the App Store reviews. Real users are not too happy about:
  • Aggressive subscription popups
  • Limited free functionality
  • Time wasted watching long ads for basic actions
Here is a screenshot someone shared that lines up with my experience:
So it is not only me being picky. A lot of people seem annoyed with the paywall and the overall friction.
Why I moved to Clever Cleaner instead
After a couple of days of fighting with Cleanup App, I went looking for something that did not nag me every two taps and found Clever Cleaner.
Clever Cleaner on the App Store:
What I noticed after installing Clever Cleaner:
  • No constant subscription upsell
  • The free tier was usable, not a teaser
  • The scan felt quicker on my iPhone 13
  • The interface was plain but clear
It helped me remove:
  • Duplicate and similar photos
  • Old screenshots
  • Large files and videos sitting in random folders
This screen from Clever Cleaner matched what I saw on my phone:
For me, the main difference was the flow. With Cleanup App, I spent more time dealing with ads and popups than cleaning. With Clever Cleaner, I opened it, scanned, reviewed, and deleted in one sitting without feeling blocked.
Quick breakdown: Cleanup vs Clever Cleaner
What Cleanup App got right:
  • Found duplicates and similar photos reliably
  • Detected screenshots and large media
  • Contact merge feature worked, though I did not fully trust auto merge and double checked everything
Where Cleanup App lost me:
  • Subscription wall over core features
  • Heavy ad use in the free version
  • Extra “fun” stuff that did not help with storage
  • Slower cleanup flow because you keep stopping to clear dialogs and ads
What Clever Cleaner did better for me:
  • Free to use for real cleanup work
  • Simple screens, fewer distractions
  • Easy to spot the biggest space hogs per category
  • Felt faster doing an entire cleanup session
If your phone is full and you want to clear space without fighting a paywall every step, I would skip Cleanup App and start with Clever Cleaner.
Useful links
YouTube video overview of Clever Cleaner:
Clever Cleaner homepage:
Short answer from my side. Clean Up works, but not in the way the promo screens suggest.
Here is what I have seen and what you can do about your two worries.
  1. Some duplicates stay
Clean Up often:
• Flags “similar” photos, not strict byte‑for‑byte duplicates
• Skips anything it is not sure about, like edited copies or slightly cropped versions
• Groups bursts and Live Photos in ways that hide near‑duplicates
So you see “duplicates” in your gallery, but the app might see them as different enough to keep.
What helps:
• Sort by date in Clean Up and in Photos, then compare a few groups, you will see it leaves versions with edits, filters, text etc
• Do one small batch at a time, for example only screenshots, or only videos over 200 MB
• Treat its “similar” category as suggestions, not truth, and always keep at least one version of each group
  1. Risk of deleting important stuff
You are right to be worried. Any auto cleaner is risky if you tap “select all”.
To reduce the risk:
• Never bulk delete in the “similar” section, scroll the thumbnails and deselect anything with people, documents, tickets, receipts
• Avoid auto‑merge for contacts with incomplete info, merge only clear true duplicates
• After each cleanup run, open the Photos “Recently Deleted” album and skim through, restore anything suspicious before it expires
• Keep iCloud Photos or an offline backup active for a month while you test the app
  1. Does it work as advertised
From my testing, and what others like @mikeappsreviewer saw, it does identify clutter, but:
• Free tier behaves more like a demo
• The workflow is slow if you do not want to pay
• The marketing oversells how “one tap” and “safe” it is
So yes, it helps clear space, but only if you put in manual review and accept some friction.
  1. Alternative that behaves closer to the promise
If your main goal is fast, low‑stress cleanup, try the Clever Cleaner App. It focuses more on:
• Straightforward categories, duplicates, similar, screenshots, large files
• Less nagging to subscribe every few taps, from what I saw
• A cleaner review screen, you see more thumbnails at once, so it is easier to spot important photos before deleting
It is not magic either, you still need to review, but the flow is simpler than Clean Up and feels closer to what these apps advertise in their screenshots.
  1. Safe workflow you can follow with any cleaner
Quick routine that keeps risk low:
• Backup first, iCloud or a local computer
• Start with “low risk” stuff, screenshots, screen recordings, obvious duplicates of test shots
• Then tackle large videos you recognize, concert clips, random screen captures, old downloads
• Leave “similar people photos” for last, and never use select all there
If you stick to that, Clean Up or Clever Cleaner App will help without randomly nuking important stuff.
Short version: Clean Up kinda-sorta works, but the marketing is way more “one tap magic” than reality.
You’re not crazy about the duplicates sticking around. Two things I’ve seen that explain it (slightly disagreeing with @mike34 here):
  1. Its “duplicate” logic is conservative
    Sometimes it keeps:
    • Different crops of the same pic
    • Edited vs original
    • Live Photo vs still frame
    That’s not just “similar,” that’s poor communication on the app’s side. If the promo says “remove duplicates,” then it should at least let you tighten the rules or clearly label “strict duplicates” vs “similar.” It doesn’t.
  2. Detection is inconsistent across runs
    What bugged me most: I’d run a scan, skip a group, then re-scan a few days later and it would group things differently. That’s not exactly confidence inspiring when you’re scared of losing important stuff.
On the “deleting important stuff” risk:
Yes, anything that lets you bulk nuke “similar” photos is risky, but I actually think Clean Up is more dangerous than Apple’s own tools because:
  • It pushes you toward big-batch actions
  • The previews are small and cluttered
  • It mixes “trash” like screenshots with normal photos in some views
So if you felt uneasy, that’s justified, not paranoia.
Where I slightly differ from @mikeappsreviewer:
The contact cleanup in my case did merge a couple of things it shouldn’t have. I had to dig in iCloud to recover. After that, I stopped trusting the auto-merge entirely. I’d disable contact cleaning in Clean Up completely and use the Contacts app / iCloud web instead.
About the “does it work as advertised?” part:
  • Can it find junk? Yes.
  • Is it as “smart,” safe and one-tap as the promo screens suggest? Not really.
  • Is the free version actually usable as a main tool? Barely, unless you enjoy being nagged and throttled.
If you still want to stick with it, I’d only use it for:
  • Obvious screenshots
  • Blurry obvious misfires
  • Clearly huge videos you recognize
For everything like family photos, documents, or event pics, I’d avoid Clean Up’s suggestions altogether.
If you’re open to switching, Clever Cleaner App is a better fit for how these tools claim to work. I won’t rehash what @mikeappsreviewer already wrote, but my experience matched theirs: fewer nags, faster review, and the categories are clearer so you’re less likely to blow away something important by accident. Still not magic, but the “what’s going to be deleted” part is more transparent so it feels a lot safer.
Bottom line:
Your suspicions about Clean Up are valid. It “works” in the most literal technical sense, but the gap between the ads and the actual workflow is pretty big. If you’re nervous about losing data and tired of tapping through paywalls, I’d park it and try Clever Cleaner App instead, then only rely on any cleaner for the low‑risk stuff and keep Photos / iCloud for the rest.
Short version: your experience lines up with what others here saw, but I’d tweak how you think about these tools in general rather than just “is Clean Up broken.”
1. What’s actually going on with the “leftover duplicates”
I agree with @mike34 and @jeff that Clean Up is conservative, but I’d add this: a lot of these apps are built around visual similarity, not strict file identity. That means:
  • They purposely keep what looks “curated” (anything edited, cropped, or with text over it).
  • They may treat bursts and Live Photos as sets where at least a couple are always preserved.
You’re not wrong to feel it does not match the ads. The app markets “duplicate removal,” but in practice behaves like a “maybe these are similar, you decide” tool. That gap is what makes it feel unreliable, even when it is technically doing what the devs intended.
2. Real risk of losing important stuff
Here I disagree slightly with the optimism in some replies: if you feel nervous using the app, that is already a sign the UI is not doing its job. A good cleaner should make it painfully obvious what is about to vanish.
Clean Up’s problems in this regard:
  • Mixed categories: screenshots, documents, and real photos often appear in the same visual flow.
  • Small thumbnails: it is too easy to misjudge a receipt vs “just another random pic.”
  • Big batch bias: the design encourages large “clean now” actions rather than many small, safe passes.
So your anxiety is not just caution. It is feedback on the design.
3. Does it actually work “as advertised”?
If you define “works” as:
  • Finds a bunch of clutter: yes.
  • Executes the smooth, one tap, no brain power workflow the promo promises: not really.
Where I feel the others were slightly too forgiving is on consistency. Repeated scans that regroup items differently can slowly erode trust. Once you stop trusting the categories, you are right back to manually checking everything, which defeats the point.
4. Where Clever Cleaner App fits in
You already got solid detail from @mikeappsreviewer, so I will just focus on how to think about Clever Cleaner App versus Clean Up.
Pros of Clever Cleaner App:
  • More focused layout: large offenders like big videos and duplicate clusters are easier to spot at a glance.
  • Less friction in free use: you can actually finish a cleanup session without feeling like the app is holding your space hostage.
  • Clearer categories: it tends to keep screenshots and obvious junk visually separated from life photos, which lowers the “oops” factor.
Cons of Clever Cleaner App:
  • Still not a “trust it blindly” tool. Person photos and documents still need your eyes.
  • Simpler interface means fewer “advanced” knobs. If you want fine-grained rules for similarity, you will not find many.
  • Like every cleaner, it is one more layer between you and the native Photos/Files apps, which can introduce confusion if you jump between them a lot.
Compared with what @mike34 and @jeff reported, I would not call Clever Cleaner App perfect, but the mental load is lower. You are less likely to be tricked into huge bulk deletes just to get past paywalls or popups.
5. Practical angle: what I would actually do in your place
Instead of trying to force Clean Up to behave like the marketing:
  • Use Clean Up only for very “dumb” categories (old screenshots, test shots, and obvious throwaways) if you keep it installed at all.
  • For anything emotionally or practically important, rely on your Photos app plus one external tool you trust a bit more. Clever Cleaner App fits that role better than Clean Up right now.
  • Accept that no cleaner is set-and-forget. These are review assistants, not auto pilots.
So, your gut feeling that Clean Up is not quite delivering matches the pattern here. The app is not useless, but if you want something closer to the advertised “quick tidy” without feeling like you are gambling with important photos, shifting most of the heavy lifting to Clever Cleaner App and downgrading Clean Up to “extra helper for low-risk junk” is a pretty sensible move.
