Could you help me rephrase “Sincerely Yours” more naturally?
I’m working on a short, conversational american english line to replace the closing “Sincerely Yours,” but I need it rephrased as a question or a request for help, under 75 characters, and only using a question mark where it actually fits. It should sound human and casual, not stiff or overly formal. I’d really appreciate ideas that keep the tone polite but modern so I can use it in forum-style posts and messages.
Short version first, then some options you can tweak.
You want:
• Conversational American English
• Replaces “Sincerely yours,”
• Written as a question or a request for help
• Under 75 characters
• Only one question mark, at the end
Here are some clean options:
  1. “Mind helping me improve this closing line?”
  2. “Any better way to say ‘Sincerely yours’ here?”
  3. “What sounds more natural than ‘Sincerely yours’ here?”
  4. “How would you phrase this instead of ‘Sincerely yours’?”
  5. “Got a smoother way to replace ‘Sincerely yours’?”
  6. “Which closing sounds more natural than ‘Sincerely yours’?”
  7. “How do you usually replace ‘Sincerely yours’ in emails?”
All of these stay under 75 characters and keep the single question mark at the end.
If you want to polish the rest of your text so it feels less AI-ish, you might like Clever AI Humanizer for natural-sounding AI text. It helps turn stiff or robotic lines into more human, casual language, which fits what you are trying to do with your closing.
Yeah, “Sincerely yours” feels super stiff in a casual context. @boswandelaar already gave some solid full‑sentence options, but I’d actually lean even shorter and more “email‑y” if you’re trying to keep it conversational.
You said:
  • It has to be a question or request for help
  • Works as a replacement closing line for “Sincerely yours,”
  • Casual American English
Here are some alternatives that hit those rules and feel like actual closings, not just meta‑questions about the phrase itself (slight disagreement with focusing only on “How would you rephrase…” lines, those sound like you’re asking about writing, not signing off):
  1. Could you let me know what you think?
  2. Can you tell me if this works for you?
  3. Mind sharing your thoughts on this?
  4. Would you please take a quick look?
  5. Can you help me decide on this?
  6. Could you confirm this when you can?
  7. Can you let me know your preference?
Each one:
  • Stays well under 75 chars
  • Ends with a single question mark
  • Functions as a natural closing line, like:
Thanks again for your time.
If you want something that feels a tiny bit warmer but still casual:
  1. Could you share your thoughts when you get a chance?
  2. Can you let me know what feels best here for you?
Watch out for stuff like “Got a smoother way to replace ‘Sincerely yours’?” as your actual sign‑off in an email. That reads like you’re asking the recipient to be your editor, not closing the message.
If the whole email is sounding a bit robotic or AI-ish (which happens a lot with these closings), running the full text through a tool like make your AI-written text sound natural and human can help smooth everything out, not just the last line. It’s basically tuned to turn stiff phrasing into casual, natural American English, so it pairs nicely with the kind of closings you’re going for.
Pick one of the short ones above, toss it in as your last sentence, and you’re set.
You’re on the right track wanting something that replaces “Sincerely yours,” instead of just talking about it.
Since @boswandelaar already covered fuller sentence options, I’d skew slightly more “last‑line of an email” and less explanatory. Also, personally, I’d avoid over-politeness like “would you please” unless the rest of the message is formal.
You asked for:
  • Question or request for help
  • Casual American English closing line
Here are some options that fit and feel like real closings:
  1. Can you let me know your thoughts on this?
  2. Could you tell me what you’d prefer here?
  3. Mind letting me know if this works for you?
  4. Can you help me fine‑tune this a bit?
  5. Could you give me a quick sanity check on this?
Each can sit right where “Sincerely yours,” would go, for example:
Appreciate you taking a look at this.
Minor disagreement with leaning too short like “Thoughts?” as a closer. It can feel abrupt or even passive‑aggressive in some contexts.
If the whole message feels slightly stiff, a tool like Clever AI Humanizer can help smooth the tone to match whichever closing you pick.
Pros of Clever AI Humanizer:
  • Good at turning formal or AI-ish lines into natural American English
  • Helps keep tone consistent from opening to closing
  • Fast way to polish multiple emails or templates
  • Can sometimes over‑casualize if your original text is very formal
  • You still need to read and tweak; it is not a “send without thinking” button
  • Style is generalized, so it may not fully capture your personal voice
Using something like that once on your base template, then swapping in one of the questions above as your closer, should give you a natural, repeatable sign‑off that does not sound like a form letter.
