How can I easily record phone calls on my iPhone?
I need to record some important phone calls on my iPhone for work and personal reasons, but I’m confused by all the different apps and methods. Some say to use Voice Memos, others mention third-party apps or voicemail tricks, and I’m worried about audio quality, cost, and privacy. What’s the simplest, most reliable way to record incoming and outgoing calls on an iPhone, and are there any legal issues I should know about?
Short version. There is no built‑in, one‑tap, “record this call” feature on iPhone because of Apple’s policy and wiretapping laws. You need a workaround.
Here are the practical options people actually use:
  1. Google Voice (free-ish, incoming calls only)
  • Set up a free Google Voice number.
  • In Google Voice settings on the web, enable “Call recording”.
  • When you get an incoming call on that GV number, press 4 to start or stop recording.
  • Google stores the audio in your GV account.
    Pros: Free, simple, legal prompts in some regions.
    Cons: Only incoming calls, not great if you use your carrier number.
  1. 3‑way calling apps (Rev Call Recorder, TapeACall, etc.)
    How they work:
  • The app gives you a special number.
  • You start a call in the app, or merge your call with their number.
  • Their server records the merged call.
  • You download the file later.
    Pros: Works for incoming and outgoing calls.
    Cons: Not free forever, involves a third party listening to all audio. Needs 3‑way calling on your carrier plan.
  1. External recorder + speakerphone
  • Put the call on speaker on your iPhone.
  • Use a second device with a voice recorder app (another phone, laptop, digital recorder).
  • Record with the mic on that device.
    Pros: Simple, no weird apps, you keep the file locally.
    Cons: Audio quality depends on room noise. Not private if you are in public. Slightly awkward for work calls but lots of people do it.
  1. Lightning or USB audio recorder
  • Use a small hardware recorder that plugs into the Lightning port or into your computer.
  • Put the call on speaker or use a TRRS splitter cable so the recorder gets audio from the call.
    Pros: Good for regular work calls. Stable, repeatable setup.
    Cons: Extra gear, some fiddling at first.
  1. Voicemail “record” trick
    This used to be more common, but many carriers break it now.
  • Start a call.
  • Add your own number as a second call so it goes to voicemail.
  • Merge the calls.
  • Your voicemail records the merged audio.
    Pros: Uses what you already have.
    Cons: Hit or miss by carrier, clunky flow, sometimes fails or records only one side.
What I would do for work calls:
  • If you want minimum hassle and you are ok with a subscription, use a reputable call recorder app that uses 3‑way calling. Test it with a friend first.
  • If you want no cloud storage, use speakerphone plus a second phone with a recorder app, then back up the files to your work drive.
Legal stuff you need to handle yourself:
  • Laws differ by country and by US state. Some places need one‑party consent, some need all‑party consent.
  • Easiest safe habit: tell the other person at the start of the call “I am recording this for notes”. If they say no, stop.
  • For work, check your company policy and maybe your legal team if it is sensitive.
Voice Memos on the iPhone alone will not record the other party on a regular phone call. It only records your mic, not the call audio path.
So, if you want “easy and reliable” on iPhone, your realistic choices are:
  • Google Voice for free incoming work calls.
  • A 3‑way call recorder app for all calls.
  • Or the low‑tech speakerphone plus second device setup.
Voice Memos and voicemail “tricks” are mostly a waste of time for what you’re trying to do. Voice Memos only records your mic, not the other person, so that’s out for real call recording. And the voicemail merge hack that @waldgeist mentioned is flaky enough that I wouldn’t build anything “important” on it.
Since you’re doing this for work and personal stuff, I’d think about it this way:
1. Decide your priorities first
  • Do you care more about:
    • Privacy / no third‑party servers
    • Convenience / one‑tap type flow
    • Call volume (occasional vs all day)
  • Also: are these mostly your outgoing calls or their incoming calls?
That decision basically chooses your tech.
2. If privacy and control matter most
Instead of 3‑way apps, I’d use a hardware path so nothing lives on some random company’s server:
  • Get a cheap USB audio interface or handheld recorder and a TRRS splitter cable for your iPhone.
  • Plug headset side into your phone, “mic/speaker” side into the recorder/interface.
  • Use wired earbuds to talk; the recorder gets the same audio.
  • Hit record before you dial.
Once it’s set up, it’s literally: plug in, hit record, make call. Very steady if you do lots of work calls, and you store everything locally where legal/compliance can actually sign off.
3. If convenience matters most
Here I actually disagree a bit with the heavy focus on Google Voice from @waldgeist. GV is fine, but juggling two numbers is a pain if people already know your main carrier number.
I’d rather:
  • Get a business VoIP service that has built‑in call recording and a proper iPhone app.
  • Examples: many small‑business phone systems let you toggle “record this call” in the app, and all the audio sits in their portal.
  • You keep your main number “ported” to that system or forward to it.
It is less “hacky” than 3‑way recorder apps, more transparent, and easier to manage if you’re ever asked to produce recordings for work.
4. For rare, one‑off personal calls
When it’s just “I need to remember what this person is telling me” once in a while:
  • Put the phone on speaker.
  • Record with your laptop / tablet / spare phone in front of you using any voice recorder app.
  • Name the file immediately after the call so you can find it later.
Yes, the quality is not studio‑grade, but for notes or personal records it’s honestly fine, and it avoids monthly subscriptions for two calls a month.
5. Legal & policy reality check
I’d treat this as mandatory, not optional:
  • Assume you must say something like:
    “Just a heads‑up, I’m recording this call so I don’t miss any details.”
  • If they say no, don’t record.
  • If it’s for work, get something in writing from your manager or legal that your method is OK, especially if recordings may contain customer data.
TL;DR practical picks
  • Heavy work use, compliant: a VoIP / business phone app with native recording.
  • Privacy & control: wired headset + splitter + hardware recorder.
  • Occasional and casual: speakerphone + second device.
Everything else tends to be gimmicky, subscription‑bait, or breaks randomly when carriers change something.
