How can I get reliable but cheap WiFi for my apartment?
I’m paying way too much for slow internet in my small apartment and it’s really affecting my ability to work from home and stream. I’ve tried calling my ISP for a better deal, but they only offer expensive bundles I don’t need. Can anyone recommend affordable, reliable WiFi options, budget-friendly providers, or tricks to lower my monthly bill without locking into a bad contract?
You have a few solid options to get cheaper but reliable WiFi in a small apartment. I’ll break it down so you can test stuff and save money without locking into junk bundles.
  1. Check all local ISPs again
    Most people only look at the big cable company. Go to BroadbandNow or your local city site and plug in your address.
    Look for:
    • Fiber first, if available. Often 300–500 Mbps for 40–60 bucks.
    • Smaller regional ISPs. They sometimes undercut the big ones by 10–20 bucks.
    Avoid TV + phone bundles. Internet only, no extras. If the site hides “internet only” plans, use online chat and ask for “unbundled, month to month, no contract.”
  2. Use a 5G or LTE home internet plan
    T-Mobile Home Internet, Verizon Home Internet, AT&T air stuff.
    They often offer:
    • Flat price like 50–60 per month with equipment included.
    • No data caps in many areas.
    Speeds depend on your local tower. In some places you get 200+ Mbps. In weaker spots you get 30–50 Mbps. Still fine for WFH and streaming if stable.
    Search “T-Mobile Home Internet Reddit + your city” to see real user tests.
  3. Share internet with a neighbor
    If walls are thin and apartments are close, you split a higher speed plan.
    • They get a 500–1000 Mbps plan. You split the bill.
    • Install a separate router on your side with a cable run between units or use a strong point to point WiFi bridge.
    Do not share the same WiFi network. Ask them to run an ethernet cable to your unit and plug into your own router. That keeps your devices on your own LAN.
  4. Stop renting the ISP router
    Most ISPs charge 10–15 per month for a mediocre gateway. That is 120–180 per year.
    Buy your own modem (if on cable) and router.
    For a small apartment, you do not need mesh. A single decent WiFi 6 router is fine. Something in the 80–150 dollar range handles WFH and streaming.
    Check your ISP’s “approved modem list” before buying.
  5. Get your WiFi layout right
    In a small apartment, placement still matters.
    • Put the router in a central spot, not in a closet or behind a TV.
    • Elevate it on a shelf, not on the floor.
    • Use 5 GHz for close devices, 2.4 GHz for further rooms.
    To see dead spots and signal strength, a WiFi analysis tool helps a lot. A good option is WiFi survey and signal optimization with NetSpot.
    You walk around your place, look at signal heatmaps, then move the router or tweak channels until speeds look stable. That can fix “slow” WiFi without spending more per month.
  6. Use your phone as a backup or stopgap
    If your mobile plan has decent hotspot data, test it during work hours.
    • Run a speedtest while tethered. You need at least 10 Mbps down and 2–3 Mbps up for most remote work and HD streaming.
    If mobile works better than your current ISP during the day, it gives you leverage when you call to cancel.
  7. Call to cancel, not to “negotiate”
    When you already know other options, talk to retentions, not sales.
    Say:
    • “Service is too expensive for the speeds I get. I am switching to X for Y dollars unless you match or beat it.”
    If they match 1 year promo pricing, take it, but put a reminder in your calendar 11 months out to cancel or renegotiate again.
  8. Rough price targets
    For a small apartment, no bundles, you should aim near these:
    • 100–300 Mbps wired speed for 30–60 per month.
    • 500 Mbps for under 70 per month in many cities.
    • 5G home internet around 50–60 per month.
If you post your ZIP code, current ISP, and what speeds you pay for now, people on the forum usually throw in more specific ISPs and router models that work well where you live.
Your ISP has you in a chokehold because they control the wire in the wall. So you beat them by changing how you use that wire and everything around it, not just by begging for a lower bill.
@waldgeist covered the big structural stuff (alt ISPs, 5G home internet, neighbor-sharing, stop renting hardware). I’ll hit different angles so you’ve got more toys in the toolbox:
1. Separate “speed problem” from “WiFi problem”
Right now you just know “slow.” That could be:
  • Crappy WiFi inside your apartment
  • Overloaded ISP in your area
  • Garbage modem or bad signal on the line
Before changing plans, test:
  • Plug a laptop directly into your router with ethernet
  • Run 2–3 speedtests at different times of day
    If wired is fast but WiFi is slow, your ISP is not the main villian. Your internal setup is.
This is where a tool like visualizing your WiFi coverage and performance is actually useful, not just marketing fluff. It shows:
  • Where your signal drops
  • Which channels are overcrowded (neighbors’ routers stomping on yours)
    Move router, change channels, done. That alone can “magically” fix streaming lag in a tiny apartment.
2. Avoid the trap of overpaying for huge speeds
Mild disagreement with a common assumption: you probably don’t need gigabit in a small apartment if it’s mainly you working from home + streaming.
For most people:
  • 50–100 Mbps down
  • 10–20 Mbps up
is fine for:
  • 1–2 Zoom calls at once
  • Netflix / YouTube / Disney+ in HD or 4K
  • Normal browsing & downloads
What kills you is jitter, latency and crap WiFi, not “only 100 Mbps.” So look for the cheapest stable plan, not the highest speed number. ISPs love selling you 500–1000 Mbps because it sounds big and justifies the bundle scam.
3. Use “dirty tactics” with your current ISP
You said they only push bundles. Try this playbook:
  1. Call and go straight to “cancel service,” not “change plan.”
  2. Tell them exactly:
    • “I only want stand‑alone internet. No TV, no phone, no home security.”
    • “If you can’t do that I’m switching to [cheapest competitor or 5G home option] this week.”
  3. If they still push a bundle, say:
    • “Ok, cancel date X. I’ll move to [other provider].”
  4. Wait. Retention teams sometimes call back with a hidden internet‑only plan.
Is it annoying? Yup. But it works more often than apoligizing and asking nicely.
4. Stop paying for fake “WiFi upgrades”
A lot of ISPs sell:
  • “Premium WiFi”
  • “Whole home WiFi”
  • “WiFi boost service”
In a small apartment, this is almost always a ripoff. You do not need:
  • Mesh systems with 3 access points
  • Monthly fees for “managed WiFi”
You just need:
  • One solid WiFi 6 router placed properly
  • Proper channel selection (NetSpot really helps here)
  • To turn off the ISP’s WiFi and only use your own router
The only time I’d pay for extra gear is if your unit has crazy thick walls or weird layout. Most “small apartment” setups don’t.
5. Use your phone and data plan as leverage
Not just as backup like @waldgeist said, but as a bargaining chip and sometimes a main solution:
  • Test your phone’s hotspot at peak hours
    If your mobile hotspot is getting stable 20–40 Mbps, that’s legitimately usable for:
  • Work from home
  • HD streaming (maybe not 3 TVs at once, but enough)
If your hotspot beats your wired service, you can:
  • Drop to a cheaper, lower‑speed wired plan and rely on hotspot as extra
  • Or in some cases, bail on wired entirely and go 5G/LTE home internet
Not ideal, but better than paying “top tier cable” money for 1999 speeds.
6. Think in “total monthly cost,” not “ISP bill only”
Example:
  • You pay $90/mo for crap ISP + their rental router
  • You could pay $60/mo for a cheaper plan + $120 once for your own router
Over 2 years:
  • Old setup: $90 × 24 = $2160
  • New setup: $60 × 24 + $120 = $1560
That’s $600 saved for the same or even better real‑world performance, just by:
  • Downgrading speed
  • Owning your own hardware
  • Fixing WiFi layout with something like NetSpot instead of “premium WiFi”
7. Keep your future self from getting wrecked again
Whatever you switch to:
  • Avoid contracts if you can
  • Set a calendar reminder for when promo pricing ends
  • Screenshot the “promotional offer” page or note down the plan name and price
When the promo period ends, they quietly hike the bill and hope you don’t notice. You call immediately and renegotiate or switch.
TL;DR practical path for you:
  1. Test wired vs WiFi so you know where the real bottleneck is.
  2. If WiFi is the weak link, fix placement, channels, and router with help from NetSpot before touching your plan.
  3. Drop to a lower‑speed, cheaper internet‑only plan if you can. Do the “cancel” call game.
  4. Keep your own router, no ISP “premium WiFi,” no bundles.
  5. Use mobile hotspot / 5G home internet as either backup or your main provider if it truly performs better in your area.
That combo usually gets people in small apartments down into the $40–60/month range with stable enough service to work and stream without wanting to throw the router out the window.
Skip repeating what @himmelsjager and @waldgeist already covered about changing ISPs and ditching bundles. I’ll focus on squeezing performance out of whatever pipe you end up with, so you can sometimes stay on a cheaper tier without suffering.
1. Stop guessing where the bottleneck is
Instead of just “my WiFi sucks,” actually map what happens between device and internet:
  • Run a wired speed test from a laptop.
  • Then run the same test on WiFi from the same spot.
  • Repeat during peak evening hours.
If wired is close to your plan speed but WiFi tanks, your problem is inside the apartment, not the plan. This is where something like NetSpot is useful: it gives you a visual map of your signal so you see which walls or neighbors’ networks are wrecking you.
NetSpot pros:
  • Easy way to see dead zones and overlapping channels.
  • Lets you experiment with router placement instead of buying random gear.
  • Good if you live in a crowded building with tons of networks.
NetSpot cons:
  • It will not fix a bad ISP line or oversold node.
  • There is a learning curve if you want to use the more advanced survey features.
  • It can tempt you into obsessing over tiny optimizations that do not matter if your base plan is terrible.
Competitors to NetSpot exist (basic WiFi analyzer apps, router vendor tools), but most of those either show less detail or lock you into one brand of hardware.
2. Use data to choose the right speed tier
Small disagreement with both earlier posts: sometimes 50 to 100 Mbps is not enough if:
  • You upload a lot (video calls plus cloud backups).
  • Multiple people stream 4K at once.
But you do not need gigabit in a small apartment either. Use your own measurements:
  • Note your maximum real use: peak simultaneous Zoom calls, streams, downloads.
  • Compare that to your wired test.
  • If you are never saturating more than half of your current speed, you can likely drop one tier and save.
Your goal is “just enough headroom,” not marketing bragging rights.
3. Let the router do smarter work
Both previous answers said “buy a decent WiFi 6 router,” which I agree with, but go one step further:
  • Turn on Smart Connect only if your router actually handles band steering well. Some do a bad job and cause random disconnects.
  • Prioritize work devices with QoS. Mark your work laptop and phone as high priority so Netflix on the TV does not kill Zoom.
  • If your router supports it, schedule automatic reboots once a week at like 3 am. Sounds silly, but cheaper consumer gear often behaves better with a regular reset.
A tool like NetSpot helps you pick the least crowded channel first, then you fine tune on the router.
4. Exploit apartment layout quirks
In tiny apartments it is easy to think “anywhere is fine,” but:
  • Avoid placing the router near the microwave or big metal appliances.
  • If you have concrete or brick internal walls, position the router so the signal goes through doorways rather than straight through the wall.
  • If you end up sharing a connection with a neighbor (as mentioned by the others), use a wired run between units when possible, then use NetSpot to ensure your two WiFi networks use different channels and do not step all over each other.
5. Mix connections for reliability
You do not have to pick exactly one service:
  • Use a cheaper wired plan as your main.
  • Keep a modest mobile plan with hotspot as backup when the wired line dies.
  • Some routers support WAN failover so they automatically switch to phone tethering or a USB modem when the main line is down.
This combo lets you accept a slightly lower speed tier and lower bill while still having “professional enough” uptime for remote work.
Bottom line:
Use tools like NetSpot to fix the in-apartment WiFi mess and prove where the real problem is, then you can safely downgrade to a cheaper plan or switch technologies without guessing. The others already gave you the “which provider” playbook; this is the “make whatever you pick actually feel fast” side of the equation.
