My iPhone photo library has gotten out of control with duplicates, screenshots, old videos, and random downloads taking up storage. I’m not sure the best way to organize, delete, and back up photos without losing anything important. What’s the safest way to clean up an iPhone photo library?
The fastest thing for me was to stop trying to delete everything one photo at a time. I had about 55,000 photos and videos, and my first attempt was just sitting there scrolling, selecting, deleting, scrolling more. After a few hours it felt like I’d barely made a dent.
I’d start with the regular Photos app if you’re just cleaning out obvious junk. It’s still good for basic cleanup. Use the swipe-to-select gesture instead of tapping every photo individually, because that alone saves a ton of time. I also found it easier to work inside specific albums instead of staring at the full library. Screenshots, downloads, videos, whatever. One bucket at a time is way less annoying.
Also check whether the album has a Select All option. If it’s an album full of stuff you already know you don’t want, like old screenshots, you can clear it way faster that way.
Where the Photos app started falling short for me was duplicates and near-duplicates. Apple’s Duplicates album is useful, but it’s pretty limited. My problem wasn’t just exact copies. It was ten versions of the same shot, burst photos, random Live Photos, old screenshots, and big videos taking up way more space than regular pictures.
That’s when I used Clever Cleaner, and that ended up saving the most time.
The useful part was that it grouped similar photos together instead of only looking for identical files. It also separated screenshots, found large videos, suggested the best photo in a group, and let me turn Live Photos into regular still photos when I didn’t care about keeping the motion. So instead of digging through 55,000 items, I was reviewing smaller groups that actually made sense.
I still checked things before deleting them, but the app handled most of the sorting. What I thought would take multiple weekends ended up being something I got through over a couple evenings.
If you’re doing this to lower iCloud storage too, just remember that iCloud Photos is the same library across your devices. Deleting something from your iPhone deletes it from iCloud Photos as well. That’s fine if you’re trying to clean everything up, but it’s not the same as just removing something from the phone.
And after deleting, go empty Recently Deleted. A lot of people forget that part. Until it’s cleared, or until it clears itself later, those files can still count against your storage.
If you still have a huge library after dealing with duplicates, go after the big stuff first. For me, the main space was being eaten by:
- long videos I forgot I recorded
- screen recordings
- old screenshots
- Live Photos
- random images and videos saved from messaging apps
Deleting a few large videos freed more space than removing hundreds of normal photos.
One last thing that helped was doing the final cleanup on a computer. After I got rid of the obvious junk, I connected my iPhone to my Mac and reviewed the rest on a bigger screen. Comparing similar photos is just easier when you’re not doing it all on a phone.
I also wouldn’t try to finish it in one day. That was the part that made me hate the process the first time. Now I just spend 10 or 15 minutes every week clearing screenshots, blurry shots, and duplicates before they turn into another giant mess.
That mix of Photos app cleanup, duplicate grouping, and going after big videos first was the quickest method I found.
If your goal is mostly to free up space on the iPhone, cleaning the library and freeing phone storage are not always the same thing. With iCloud Photos on, your phone may already be keeping smaller versions locally if “Optimize iPhone Storage” is enabled, so deleting hundreds of normal photos might not change much. Big videos, screen recordings, and downloaded media usually matter more.
I agree with @mikeappsreviewer that working in buckets is less painful, but I’d be more cautious before doing any big deletion pass. Make a separate backup first, meaning something that is not just iCloud Photos syncing the same library. Import to a Mac or PC, copy to an external drive, or use another cloud service if that is your setup. Then spot-check that the files actually open before you start deleting. iCloud is convenient, but it is not a “deleted by accident” safety net once everything syncs.
For cleanup, I’d start with the boring searches inside Photos: “screen recordings,” “screenshots,” “receipts,” “WhatsApp,” “Instagram,” “TikTok,” or whatever apps tend to dump junk into your camera roll. Then do videos sorted by size if possible, because that is where the storage usually disappears. A cleaner app like Clever Cleaner can be useful for similar shots, but I would still review anything it marks before deleting. The annoying part is that the safest method is slower, but it beats realizing a week later that your only copy of something was in the batch you cleared.
Deleting an album usually does not delete the photos inside it, it just removes that album container. That trips people up when they think they “cleaned” a folder and then wonder why storage did not move. If you want a safer first pass, use Albums and Search only as ways to find the junk, then delete the actual items and check Recently Deleted after. I’d start with the stuff that is obviously disposable, like screen recordings, failed videos, memes, receipts, and app downloads, before touching family photos or trips. Duplicates and cleaner apps can wait until after that, because the biggest win is usually removing junk you already know you do not want.
