How To Compress Photos On IPhone Without Using A Computer?
My iPhone photos are taking up too much storage, and I need to reduce their file sizes without transferring them to a computer. What’s the easiest way to compress photos directly on an iPhone while keeping decent image quality?
The best option depends on whether you're trying to share a smaller file or clear space on your iPhone.
For emailing, uploading, or submitting one or two photos, iOS already has a decent built-in method:
  1. In Photos, select the image and tap Share.
  2. Choose Save to Files, pick a folder, and tap Save.
  3. Open Files and locate the saved image.
  4. Touch and hold it, then select Quick Actions > Convert Image.
  5. Choose JPEG and select Small, Medium, or Large.
That creates a separate, smaller copy you can upload or send. It works fine for occasional use, but doing this photo by photo is a pain if storage is the real problem.
For cleaning up a large library, an app such as Clever Cleaner is more practical. It can process photos in batches and find duplicate or similar pictures, large videos, old screenshots, and Live Photos you may not need. I recovered more space than expected this way without manually going through thousands of images.
Basically, use Files > Convert Image when you only need a smaller file for sharing. If you're trying to reclaim storage across your whole photo library, a dedicated compression or cleanup app will save a lot of time.
Compressing photos won’t free much space unless you delete the originals afterward and empty Recently Deleted. For a large library, I’d enable Optimize iPhone Storage first since it keeps smaller device copies without making you manage duplicates manually.
Don’t blindly convert HEIC photos to JPEG. iPhones already save most photos in a space-efficient format, so conversion can sometimes make the file larger while lowering quality. For future shots, keep Camera Format set to High Efficiency; for existing photos, test any compression app on a few images and compare file sizes before processing the whole library.
Don’t compress the whole library until you know whether the problem is iPhone storage or iCloud storage. As @golden_thread195 suggested, Optimize iPhone Storage is the least destructive fix, but it requires iCloud Photos and enough iCloud capacity. It reduces local storage use, not the space those photos occupy in iCloud.
If you want genuinely smaller files without paying for an app, make a Shortcut using Select Photos, Resize Image, and Save to Photo Album. That can batch-resize copies to something reasonable, such as 2000 pixels on the long edge. Check a few copies for quality and metadata before doing more, then delete the originals and clear Recently Deleted. Keep full-resolution originals for anything you may print or edit later.
Compressing photos rarely gives you the win people expect. If your storage bar is red, it’s usually a handful of videos and maybe your messages cache eating the space, not thousands of stills. Before you touch a single image, go to Settings, General, iPhone Storage and actually look at what’s listed. I’d bet the top offenders aren’t your regular photos.
@golden_thread195 nailed the part everyone skips. A compressed copy sitting next to the original does nothing until you delete the source and clear Recently Deleted, which holds it for 30 days. And @openhive5150 is right that blindly converting HEIC to JPEG can leave you with bigger files and worse quality. That combo is the trap: people convert, feel productive, and their storage number doesn’t budge.
The Clever Cleaner suggestion up top makes sense as a first sweep, mainly for spotting near-duplicate bursts and Live Photos you forgot about. I’d treat it as a way to find the junk, not as a magic compressor. For the actual space, sort your videos by size and deal with the top five first. That’s usually where the gigabytes are hiding, and it takes about two minutes.
If you do want smaller stills for sharing, the Shortcut route @d4rk_cipher described is the least annoying way to batch it without paying anything. Just keep originals of anything you might print later, because 2000px looks fine on a screen and rough on paper.
