How To Disable Gemini On Android
I updated my Android phone recently and it looks like Gemini replaced parts of Google Assistant and some search features. Now it keeps popping up when I long-press the power button or use certain gestures, and I find it distracting and confusing. I’d like step-by-step help to fully disable or remove Gemini from my Android, or at least stop it from launching and taking over Assistant and search. What settings or workarounds can I use to turn it off without breaking anything important?
Yeah, Google pushed Gemini pretty hard in the last updates. You have a few ways to turn it off or at least hide it, depending on device and region.
Try these in order:
  1. Switch back to Google Assistant as default
    • Open Google app
    • Tap your profile picture
    • Settings
    • Google Assistant or Search, Assistant & Voice
    • Look for “Digital assistants” or “Assistant”
    • Set “Google Assistant” instead of “Gemini” if it shows up
    On some phones there is a separate “Gemini” toggle in that menu. Turn it off.
  2. Change the long press power button action
    On Pixels and some others:
    • Settings
    • System
    • Gestures
    • Press and hold power button
    • Change from “Assistant” or “Gemini” to “Power menu” or “Nothing”
    On Samsung:
    • Settings
    • Advanced features
    • Side key
    • Under “Press and hold” pick “Power off menu” instead of “Wake Bixby / Assistant / Gemini”
  3. Change long press home or navigation gesture
    • Settings
    • System
    • Gestures
    • System navigation
    • Tap the gear next to Gesture navigation or 3 button nav
    • Turn off “Hold Home for Assistant” or any shortcut that triggers assistant
  4. Turn off Gemini as default assistant app
    • Settings
    • Apps
    • Default apps
    • Digital assistant app or Assistant & voice input
    • Change Gemini to “None” or “Google” or “Device assistance app: None”
    On some devices you must tap the gear next to the assistant and then disable Gemini specific stuff.
  5. Disable Gemini app or feature (if it shows as an app)
    • Settings
    • Apps
    • Show all apps
    • Look for “Gemini” or “Gemini app”
    • If it has a “Disable” button, hit that
    • If it only has “Uninstall updates” then do that, it often rolls it back to standard Assistant behavior
  6. Change the search bar / lock screen shortcut
    If Gemini pops up from the search bar or lock screen:
    • Long press on the home screen
    • Tap Home settings or similar
    • Look for “Search” or “Google app” options
    • Switch to standard Google search if there is a Gemini toggle
Extra notes from other users and my own phone:
• On some EU devices Gemini is still “experimental” so there is a clear “Try Gemini” toggle inside the Google app. Turn it off and it stops hijacking assistant.
• On newer Pixels, once you opt in to Gemini as assistant, Google hides the rollback a bit deeper in the Google app settings. It took me like 5 mins of tapping every sub menu to find “Use Google Assistant instead”. It was under:
Google app → profile pic → Settings → Gemini → “Use Gemini instead of Assistant” toggle. Turn that off.
If none of these work, the nuclear options:
• Roll back Google app
Settings → Apps → Google → 3 dots → Uninstall updates
Then disable auto update for a while in Play Store.
• Use a third party launcher so you avoid the Gemini integrated search at least on the home screen.
Google keeps tweaking this, so menu names might differ a bit, but those paths cover most Pixels, Samsungs and OnePlus devices people reported on.
Yeah, Gemini’s been a bit of an uninvited guest lately.
Since @caminantenocturno already covered the obvious menus, here are some extra angles that helped on my Pixel and a friend’s Samsung, without rehashing the same paths:
  1. Opt out inside Gemini specifically
    If Gemini is already active as your “assistant”:
    • Open the Google app
    • Tap the Gemini icon or card at the top
    • Go into its settings (gear icon or 3‑dot menu)
    • Look for something like “Use Gemini instead of Assistant” / “Gemini as default assistant”
    • Turn that off
      This is not always in the standard Assistant menu; sometimes it’s hidden only inside the Gemini page itself.
  2. Kill gesture triggers from the launcher side
    On some launchers, Gemini hooks into the search or swipe-up:
    • Long press on home screen → Home settings
    • Look at “Search,” “Search bar,” or “Swipe up for” options
    • Change provider to “Google” or “App search only”
    • Disable “Show generative results” or “AI suggestions” if there’s a toggle
      That stops Gemini popping up when you swipe up from the dock or tap the search bar.
  3. Use activity shortcuts to jump to buried settings
    If dev options are on or you don’t mind a bit of tinkering, install a shortcut/activities app (like Activity Launcher) and search for:
    • “Gemini”
    • “Assistant settings”
      Often there’s a hidden activity named something like com.google.android.apps.search.assistant or gemini_settings. Opening that can reveal a direct toggle to revert back to classic Assistant even when the normal UI pretends it’s gone.
  4. Region & account trick
    This sounds dumb but worked for a couple people:
    • In the Google app → profile → Settings → Gemini / Assistant
    • Temporarily change language or region (e.g. to one where Gemini is not fully rolled out)
    • Force stop the Google app and clear cache (not data first)
    • Reopen and you sometimes get a “Try Gemini” card again instead of it being forced on, which you can decline.
      Bit hacky, but if your account was “hard opted in,” this can reset that flag.
  5. Lock screen & notification shortcuts
    Gemini sneaks in here too:
    • Settings → Lock screen
    • Look for shortcuts like “Left shortcut / Right shortcut” or “Lock screen shortcuts”
    • If one is set to Assistant / AI / Search, change it to something else or None
      Also check:
    • Settings → Notifications → Advanced → “Smart suggestions” / “Smart assistant on lock screen”
      Disabling “AI suggestions” stopped Gemini from randomly popping predictive stuff for me.
  6. A more “scorched earth” but not full rollback
    Instead of uninstalling all Google app updates like @caminantenocturno suggested, you can try just neutering the bits that wake Gemini:
    • Settings → Apps → Google
    • Permissions → remove Microphone & Voice control if you never use voice
    • Open-by-default → clear defaults
      That way, when Android tries to call the assistant, it fails silently or asks which app to use, which lets you pick classic Google, or none.
  7. Try a different assistant app as a decoy
    If your phone insists on having some assistant:
    • Install another simple assistant app (even something light and offline)
    • Settings → Apps → Default apps → Digital assistant app
    • Select that other app instead of Gemini
      Rough workaround, but it prevents Gemini from ever being launched even if gestures are left on by accident.
Honestly, Google is playing whack‑a‑mole with these toggles, so it might take a mix of:
  • Remove Gemini as default inside Google app
  • Kill its gesture / lockscreen / search bar hooks
  • Optionally strip permissions so even if it fires, it can’t really do much
Once I did all that, Gemini basically vanished from my day‑to‑day use, and old Assistant + plain search were back without having to fully downgrade the Google app.
Quick troubleshooting rundown focused on things not already covered by @caminantenocturno, and skipping the obvious menus:
  1. Disable Gemini’s web overlay in Chrome
    Gemini sometimes hijacks results inside the browser.
    • Open Chrome
    • Settings → Search → turn off any “AI overview” / “Generative” / “Summaries” toggles
      That does not kill Gemini as an assistant, but it stops the AI layer from showing up when you just want plain web results.
  2. Turn off “At a Glance” AI cards (Pixels especially)
    Gemini hooks into those smart cards at the top of the home screen.
    • Long press the “At a Glance” widget
    • Customize → disable “Intelligent suggestions,” “Nearby,” or any “AI” labeled row
      That removes a bunch of Gemini-flavored suggestions before they ever surface.
  3. Replace the Google search bar widget
    Instead of fighting all the hidden Gemini switches, you can sidestep the whole path:
    • Long press the Google search bar on your home screen, remove it
    • Add a different search widget, like a browser search or in‑phone search widget
      This avoids Gemini triggers that piggyback on the Google bar itself.
  4. Use a third‑party launcher as a shield
    Here I slightly disagree with relying only on system toggles. On many skins, even when you “disable” Gemini in settings, some hooks stick around. A different launcher often isolates them better.
    • Install a third‑party launcher from Play Store
    • Set it as default
    • Turn off its own “smart suggestions” and “AI search” features
      This cuts off a lot of Gemini entry points: no AI swipe‑up search, no forced AI suggestions.
  5. Turn off voice hotword on the account level
    If “Hey Google” starts Gemini for you:
    • Google app → profile → Settings
    • Voice → “Hey Google & Voice Match”
    • Disable “Hey Google” on this device
      Now the long‑press or gesture might still exist, but accidental voice activations are gone.
  6. Use “Digital Wellbeing” to limit Gemini usage
    Sounds weird, but it works as a soft muzzle.
    • Settings → Digital Wellbeing → Dashboard
    • Find Google / Gemini entry
    • Set a tiny time limit (like 1 minute per day)
      After that, Gemini still launches but quickly hits its limit and becomes much less intrusive in practice.
  7. Stop account‑level personalization that feeds Gemini
    • Google account settings → Data & privacy
    • Turn off Web & App Activity and “personal results”
      Gemini becomes noticeably dumber and less pushy when it has less personalized fuel. Not a full disable, but makes it easier to ignore.
About the empty product title “”:
Pros:
  • Neutral in search results since it does not look like a marketing term.
  • Easy to slot into guides about “How To Disable Gemini On Android” for readability and SEO without sounding spammy.
  • No clear branding, so it is easy for readers to overlook.
  • Harder to distinguish in a list of tools or settings, especially beside recognizable names.
Compared with what @caminantenocturno suggested, I lean more on isolation strategies: different launcher, alternative widgets, and limiting Gemini’s “fuel” (personalization, hotword, Digital Wellbeing) rather than only hunting for the official off switch, which keeps moving around between updates.
