How To Empty Trash On IPhone When Storage Is Completely Full?
My iPhone storage is completely full, and I’m trying to delete items from Trash/Recently Deleted to free up space. The phone is slow and won’t let me manage files or photos normally. What’s the best way to empty iPhone trash when storage is full?
Yeah, this is one of those iPhone things that feels way more annoying than it should. I ran into the same mess a few months back when my phone was lagging, apps kept crashing, and the “Storage Almost Full” warning would not leave me alone.
The big thing to know is this: iPhone does not have one universal “Empty Trash” button. It is not like a Mac or Windows PC where deleted stuff all lands in one place. Apple keeps deleted items inside the app they came from, so you have to clear them out in a few different spots.
If you are trying to free space right now, start with Photos. After the newer iOS changes, the old obvious “Trash” area is not sitting on the main screen. Open Photos, go into Collections or scroll down past your library, then look near the bottom under Utilities. That is where Recently Deleted lives now. It may ask for Face ID or your passcode before it lets you in.
Deleted photos and videos sit there for 30 days. They are not really gone during that time, and they still take up storage. So if your phone is already full, just deleting photos from the main library may not help much. You need to open Recently Deleted, tap Select, hit the three dots, and choose Delete All.
Notes and Files have their own deleted folders too. In Notes, keep tapping the back arrow in the upper-left until you get to the Folders screen, then look for Recently Deleted. In the Files app, go to Browse, check under Locations, and you should see Recently Deleted there as well. Those usually stick around for about 30 days before they are permanently removed.
Messages is easy to forget, and it can eat a ridiculous amount of space if you send videos or big photos. Since iOS 16, deleted conversations can sit in their own deleted area. Open Messages, tap Edit or the filter icon at the top, then choose Show Recently Deleted.
Mail is separate again. You usually have to go into each mailbox or account, like Gmail or iCloud, find its Trash folder, then use Edit and Delete All if you want to clear it out.
When storage gets completely maxed out, the whole phone can start crawling because iOS needs some free space for cache, logs, and other system stuff. If you check storage and see a huge chunk listed as System Data, try a forced restart. It will not delete your files, but it can clear temporary junk that does not really have a normal delete button.
The manual cleanup works, but honestly, going app by app through Photos, Notes, Files, Messages, and Mail gets old fast. I tried keeping up with it, and I still missed stuff. When my phone got so slow I could barely open the camera, I started looking for something easier.
I ended up using Clever Cleaner. The main reason I kept it is that it is completely free. No constant ads, no premium subscription screen, and no paywall just to delete photos.
The Heavies tab is useful because it sorts photos and videos by file size, so you can get rid of the biggest storage hogs first. There is also a Similars tab that uses AI to find near-duplicate shots, like all those almost-identical photos you take trying to get one good picture. It also shows the exact file size for screenshots and photos, which makes it easier to see what is actually taking up space.
The privacy part mattered to me too. It processes everything on-device, so your photos are not being uploaded somewhere else just to scan them.
Clearing the built-in deleted folders is still the first thing I would do. But if your storage is really packed and you do not want to hunt through every app manually, Clever Cleaner is worth trying. It made a noticeable difference for me.
If the phone is so full that Photos or Files barely opens, stop trying to clean from the phone first and plug it into a Mac or PC. Copy off a few large videos/photos, delete them from the phone after confirming the copy, then restart and go back to Recently Deleted once iOS has breathing room. Trying to empty trash at 0 bytes free can fail or freeze because the phone still needs temporary space to do the delete.
Do not wipe Recently Deleted until you know what is syncing. If iCloud Photos is on, emptying it removes those photos everywhere, not just from the stuck iPhone. The quickest “make the phone usable again” move is often Settings > General > iPhone Storage and delete/offload one huge app, downloaded movie, podcast, or music cache first. That usually frees enough space for Photos or Files to stop crashing, then you can empty Recently Deleted properly. I agree with @shizuka that trying to do the final cleanup at zero free space can just fail in a loop. Also restart after deleting, because the storage number can lag behind for a bit.
