I’ve been trying to figure out how to make AI images, but I keep getting confusing results and I’m not sure which tools or prompts actually work. I want to create better AI art for personal projects, and I need simple advice on the best beginner-friendly image generators, prompt tips, and how to get more realistic or creative results.
Pick one tool and learn it first. Switching tools causes half the confusion.
Easy starter options:
Midjourney, strong image quality, works well with short prompts.
DALL·E, simple to use, decent prompt following.
Stable Diffusion, more control, more setup.
Use this prompt format:
subject, style, composition, lighting, colors, quality details
Example:
portrait of a cyberpunk woman, neon street, cinematic lighting, close-up, purple and blue color palette, detailed skin, sharp focus
If your results look weird, the prompt is often too vague or too packed. Keep it tight. Add details in rounds.
Do this:
- Start with 1 subject.
- Add art style.
- Add camera angle.
- Add lighting.
- Add background.
- Generate 4 to 8 versions.
- Keep the best one. Edit the prompt.
Bad prompt:
cool fantasy pic
Better prompt:
ancient wizard in a dark forest, oil painting style, full body, moonlight, fog, high detail
Use negative prompts if your tool supports them:
blurry, extra fingers, bad hands, duplicate face, distorted eyes
For personal projects, make a prompt sheet. Save prompts that worked. Small changes matter a lot. One word can shift the whole image. It takes some trial and error tbh, but once you stick to one workflow it gets way less annyoing.
Confusing results usually come from expecting the model to ‘invent your taste’ from one sentence. It won’t. @viajantedoceu is right about keeping things structured, but I kinda disagree on always starting with just one tool forever. Sometimes trying the same prompt in 2 tools teaches you faster what the prompt is actually doing vs what the model is doing.
Big thing people miss: use image references. Not just text. If your tool allows it, feed in a sketch, pose ref, color moodboard, or even a rough composition blockout. That cuts down on the random nonsense a lot.
Also, stop chasing ‘perfect prompt’ language. Prompting is less magic spell, more steering wheel. Better workflow:
- make a rough draft
- pick what is closest
- use variations/upscale/inpaint
- fix only one problem at a time
If faces are wonky, don’t rewrite the whole prompt. Just inpaint the face. If composition is bad, use a reference image next round. If the style is inconsistent, add an artist movement or medium, not 20 extra adjectives.
Another thing, aspect ratio matters way more than ppl think. Wide for landscapes, vertical for characters, square for icons/posters. Wrong canvas = awkward image half the time tbh.
For personal projects, build a mini pipeline:
idea > rough gen > select > edit > final polish in Photoshop/GIMP/Canva
AI image tools are better at drafts than finished masterpieces, imo. Once I accepted that, results got way less anoying.
The part I slightly disagree with from @viajantedoceu is the idea that structure alone fixes most confusion. Structure helps, sure, but a lot of bad AI images come from picking a model that simply isn’t good at the thing you want. Some models are great at painterly scenes and terrible at hands. Others nail product mockups but make mushy backgrounds. So before rewriting prompts for an hour, test whether the model itself is the bottleneck.
What helped me most was separating prompts into 4 buckets:
- subject
- style
- camera/composition
- quality constraints
Example:
- subject: astronaut walking through a flooded library
- style: cinematic concept art, moody blue lighting
- composition: wide shot, low angle, strong reflections
- constraints: detailed face, readable bookshelves, no extra limbs
That last part matters more than people admit. A lot of users only describe what they want, not what they want to avoid.
Also, generate in small batches and compare. If you do 20 wildly different prompts, you learn nothing. If you do 4 close variants, you start seeing patterns fast.
One more unpopular opinion: sometimes simpler prompts beat giant prompt walls. If your prompt reads like a grocery receipt, the tool may average everything into bland sludge.
Pros for ‘’: can improve readability if you’re organizing prompt notes or workflow docs. Cons for ‘’: not really essential for image quality itself, so don’t expect it to magically fix outputs.
Best mindset: treat AI art like iteration, not summoning. That shift alone makes results way less frustrating.
