How To Make An Ai Agent
I’m trying to build an AI agent for a small project, but I got stuck figuring out the setup, tools, and logic it needs to actually work. I’ve read a few AI agent tutorials, but I’m still confused about the best way to start and what steps matter most. I need help understanding how to build an AI agent without wasting time on the wrong approach.
Start smaller than most tutorials tell you.
An AI agent is usually 4 parts.
  1. Model
    This is the LLM. GPT, Claude, local Llama, whatever fits your budget and speed target.
  2. Tools
    These are functions the model calls. Example:
  • search_docs(query)
  • read_file(path)
  • send_email(to, body)
  • update_db(record)
  1. Memory
    Keep it simple first.
  • Short term memory: current chat history
  • Long term memory: saved facts in a DB or vector store
    A lot of projects dont need long term memory at all.
  1. Loop
    This is the agent logic:
  • get user goal
  • send goal + tool list + rules to model
  • if model asks for tool, run tool
  • feed tool result back to model
  • repeat until final answer
Basic flow:
User input
→ planner prompt
→ model picks action
→ tool runs
→ result goes back to model
→ model answers or picks next action
If you want the easiest setup, use:
  • Python
  • OpenAI or Anthropic API
  • FastAPI for your app
  • SQLite or Postgres for storage
  • LangGraph if you want control
  • Plain function calling if you want less magic
My honest take, skip heavy frameworks at first. They add confusion fast. Build one agent with 2 tools and one clear job. Example, “read support tickets and draft replies.”
A tiny psuedo flow:
  1. Define tools as Python functions
  2. Send tool schemas to the model
  3. Parse tool call
  4. Execute function
  5. Return output to model
  6. Stop after 3 to 5 loops
Also add guardrails:
  • tool whitelist
  • max steps
  • timeout per tool
  • log every action
  • require confirmation before destructive actions
If your agent feels dumb, the issue is often one of 3 things:
  • prompt is vague
  • tools return messy data
  • you gave it too many choices
Start narrow. Measure task success rate. Then add memory or planning if needed. Most people overbuild this stuff tbh.
You’re probably stuck because most “AI agent” guides jump straight from chatbot to “autonomous system” like there’s no middle ground. There is.
I mostly agree with @kakeru, but I’d push one thing a bit differently: don’t start by thinking “agent.” Start by thinking “workflow with judgment.” A lot of projects only need the model to choose between a few branches, not wander around making decisions forever.
A practical setup:
  • one LLM call for intent/classification
  • one execution layer with normal code
  • optional second LLM call to format/explain result
That’s way easier to debug than a full agent loop.
Example:
  • User asks: “summarize these support tickets and tell me top issues”
  • Your code:
    1. validates input
    2. fetches tickets
    3. chunks/sorts data
    4. sends only relevant text to model
    5. returns structured output
Notice the model isn’t “running the system.” Your app is. That distinction saves a ton of pain.
Stuff I’d decide first:
  • What exact decision should the AI make?
  • What must stay deterministic in code?
  • What can fail safely vs what cannot?
  • Do you need autonomy, or just tool-assisted responses?
Biggest mistake imo: giving the model raw access to everything. Better pattern is a service layer. The AI asks for “get_recent_tickets,” not direct DB/sql access. Same for files, APIs, etc. Keep permissions super narrow.
Also, define success before coding. Literally write 10 test tasks. If your agent cant pass those, adding memory/vector DB/planning won’t magically fix it. People bolt on retrieval way too early tbh.
If you want, post your project idea and ppl can tell you whether you need an actual agent or just a smart app with 2 AI steps.
