How To Pull Up Emojis On Mac
I recently switched from Windows to a Mac and I can’t figure out the fastest way to open the emoji picker while typing in apps like Messages, Mail, or in my browser. I’ve tried random keyboard shortcuts but nothing seems to work consistently. What’s the best built‑in way to bring up emojis on macOS, and can I change the shortcut if I want something easier to remember?
Fastest way on Mac:
  1. Main shortcut
    Press Control + Command + Space while typing.
    That opens the emoji picker in Messages, Mail, browsers, etc. Works in most text boxes.
  2. Keep it open as a small panel
    When the picker shows, click the tiny icon in the top right that says “Show Emoji & Symbols” or similar.
    That opens the full panel.
    Then in the Menu Bar, go to the input menu and choose “Show Keyboard Viewer” or “Show Emoji & Symbols” to reopen it faster from there.
  3. Menu bar access
    Go to System Settings > Keyboard > Text Input > Input Sources.
    Turn on “Show Input menu in menu bar”.
    After that you get a little icon top right of the screen.
    Click it, pick “Emoji & Symbols”.
  4. For some apps
    In a few apps like Slack you type a colon and the name, like :smile.
    That is app specific though.
For quick day to day use, Control + Command + Space is the one your fingers want to learn. I switched from Windows too and kept mashing Win + . out of habit for a week lol.
Honestly, I think people overcomplicate this on macOS.
Yeah, the shortcut @viajeroceleste mentioned is the “official” way, but if you’re coming from Windows and your muscle memory is totally wrecked, a couple of alternatives might feel more natural:
  1. Use the “Edit” menu in a lot of apps
    In many native-ish apps (Messages, Mail, Notes, Safari, etc.):
    Edit > Emoji & Symbols
    Not as fast as a shortcut, but it’s great while you’re still learning. You can even glance at the shortcut there until it sticks.
  2. Pin the emoji panel so it stays floating
    When the emoji window is open, drag it a bit so it becomes a small floating panel instead of popping up in-line. Then just leave it lurking on the side of your screen.
    Click in any text field, then click an emoji in that panel and it inserts directly.
    This is actually faster in practice than re-triggering the shortcut every time, especially if you do a lot of emoji-heavy typing.
  3. Use text replacements for your “top 5” emojis
    If there are a few you spam constantly, you can skip the picker completely:
    • System Settings > Keyboard > Text Input > Text Replacements
    • Add things like:
      • :shrug¯\_(ツ)_/¯
      • :angry:face_with_steam_from_nose:
        Then you just type the shortcut and hit space/enter.
        It’s dorky to set up once, but after that it’s actually faster than any picker.
  4. Safari / browser tricks
    Some web apps ignore the system picker or feel laggy. In those cases I honestly just keep a “scratch” note in Notes or Stickies with frequently used emojis, copy/paste from there, and move on with my life. Not pretty, but very fast in actual use.
Tiny disagreement with @viajeroceleste: I wouldn’t rely too much on the colon-style thing (:smile) unless you live in Slack/Discord. Every app implements it differently, and some not at all, so it’s just one more weird context switch to remember.
If you want something closest to Windows Win + ., training your hands until the Mac combo becomes pure reflex plus keeping a tiny floating emoji panel on the side is probably the least annoying long-term setup.
