I’m trying to figure out how to turn off AI on my device or app, but I can’t find the setting anywhere. It recently started showing up in features I don’t want to use, and it’s making things more confusing than helpful. I need help finding the right way to disable it.
Most apps hide it in weird places. Start here.
Check the app settings.
Look for AI, Assistant, Copilot, Gemini, Meta AI, Smart Features, Labs, or Experimental. -
Check your device settings.
On iPhone, look in Siri or Apple Intelligence.
On Android, look in Google, Gemini, Assistant, or device search settings.
On Samsung, check Advanced Features too. -
Turn off feature by feature.
A lot of apps do not give one master switch. You need to disable things one at a time. Examples:
Photos, AI editing.
Keyboard, writing help.
Browser, AI summaries.
Messaging, smart replies. -
Update your app, then check again.
Some versions move the toggle. Annoying, but true. -
If there is no off switch, your options are limited.
Use the web version.
Roll back to an older version, if your device allows it.
Switch apps.
If you post your device model and app name, people here can point to the exact menu. Half the battle is finding the dumb setting they renamed last week.
If the toggle straight up doesn’t exist, don’t waste hours hunting ghosts in menus. That’s the part I kinda disagree with from @codecrafter. Sometimes it’s not “hidden,” it’s just baked in now.
A few things that actually help:
- Check permissions, not just features. Revoke microphone, contacts, photos, calendar if the AI stuff is using those.
- Turn off cloud sync/account-level “personalization” in your account settings. A lot of AI junk rides on that.
- Disable notifications/cards/suggestions. Companies rename AI to “helpful recommendations” and pretend it’s different.
- If it’s your keyboard, switch keyboards. Seriously, easiest fix ever.
- For browsers, change the default search engine and homepage. That alone kills a lot of assistant popups.
- If it’s on a PC, uninstall the add-on/companion app. Some “AI” is just bundled software.
Worst case: adb disable on Android, Screen Time/Restrictions on iPhone, or use a different app. Annoying? yep. But sometimes the real off switch is “stop using the thing.” If you say the exact app/device, ppl can probly give the exact path.
A lot of “AI” isn’t a single switch, it’s tied to updates. That’s where I slightly disagree with @codecrafter. Sometimes swapping apps is overkill if the feature can be neutered another way.
Try this angle:
- Roll back the app version if the AI showed up after an update.
- Turn off beta/preview features. AI tools often land there first.
- Check accessibility settings. Some assistants hook into text prediction, screen readers, or smart overlays.
- Look for region/language tricks. Changing language from US English sometimes removes assistant features entirely.
- On Android, disable the app’s default roles like assistant, launcher, messaging helper, or calling support.
- On Windows, check startup items and taskbar integrations, not just installed apps.
- On Samsung/Pixel devices, search Settings for “smart,” “suggest,” “assist,” and “labs.” Vendors hide AI behind those labels.
- If it’s in messaging or email, turn off Smart Reply, Smart Compose, writing help, and summaries separately.
Pros for “”: can improve readability if it’s a text tool.
Cons for “”: can clutter the interface and feel forced.
Post the exact device/app and someone can give the precise menu path.
