I’m confused about how to properly update apps on my iPhone. Some apps say they need updates, others update automatically, and a few never seem to change at all. I’m worried I might be missing important security or feature updates. Can someone explain the correct steps to update iPhone apps and how to set up automatic updates so everything stays current?
Here is how iPhone app updates work and what you should check.
- Turn on automatic app updates
- Open Settings.
- Tap App Store.
- Under Automatic Downloads, turn on App Updates.
- Under Cellular Data, decide if you want automatic updates on mobile data or only on Wi‑Fi.
If this is on, the phone will update apps in the background when it has power, storage, and a decent connection.
- Manually update your apps
- Open the App Store.
- Tap your profile picture at the top right.
- Scroll to see “Available Updates” or “Upcoming Automatic Updates”.
- Tap Update next to a single app, or Update All.
If nothing shows, pull down on that screen to refresh.
- Why some apps show as needing updates
Common reasons:
• Automatic Updates is off.
• Phone is low on storage.
• Phone was off or offline for a while.
• You paused or canceled a pending update.
You can check storage in Settings > General > iPhone Storage. If storage is almost full, free up space and try again.
- Why some apps seem to never change
• Developers update some apps less often.
• Some updates are small bug or security fixes, you might not notice changes.
• If you got an app with a different Apple ID or region, it might stop getting updates on your current account.
To see the version of an app, open App Store, search the app, open its page, scroll down to Version History. That shows the dates and changes.
Make sure iOS itself is updated
System updates include security fixes.- Go to Settings > General > Software Update.
- Install any update that appears.
- Turn on Automatic Updates on that screen too.
Quick checklist for you
• Automatic Updates for apps turned on in App Store settings.
• Enough storage free.
• iPhone on Wi‑Fi and plugged in regularly.
• Manual check in App Store profile page once in a while.
• System iOS updated.
If you want extra control for security, open the App Store profile once a week and tap Update All. That way you know you did not miss anything important, even if the automatic process lagged a bit.
Couple of extra angles on top of what @sterrenkijker already laid out really well:
Some apps intentionally don’t update often
If an app “never changes,” check its App Store page → scroll to Version History.- If the last update was a year+ ago, that’s on the developer, not you.
- For anything security‑sensitive (banking, password managers, authenticator apps), that’s a red flag. I’d consider switching apps if those aren’t updated at least occasionally.
App saying “Update” but nothing happens
Sometimes you tap Update and it just spins or stops. Try:- Long‑press the app icon → Remove App → Delete App → reinstall from App Store. You won’t lose data for most cloud‑based apps (social, email, streaming), but games and some offline apps can lose local progress, so be careful.
- Also try signing out and back into the App Store: Settings → your name → Media & Purchases → Sign Out → then sign back in.
Mixed Apple IDs = weird behavior
If you ever:- Used someone else’s Apple ID
- Switched regions (e.g., moved countries)
Some apps will stay on your phone but stop updating. In the App Store, check the app’s page: if it shows a different Apple ID in the purchase history screen or asks you to sign in with an old account, that app is stuck in time. Only real fix is deleting it and re‑getting it under your current Apple ID, if it exists in your region.
“Auto updates on” but stuff still lags
I slightly disagree with relying purely on automatic updates like @sterrenkijker suggested. Auto updates are fine, but iOS is kind of lazy about them. To force Apple’s hand:- Keep the phone unlocked and plugged in on Wi‑Fi for a while. iOS prioritizes background tasks like updates then.
- Open the App Store once in a while, go to your profile page, then just leave it open for a minute. That often kicks off queued downloads.
For people who care a lot about security
You don’t actually have to update everything instantly if that stresses you out. What I recommend:- Update “critical” apps weekly: banking, 2FA, email, messaging, browser, cloud storage.
- The rest (games, random tools) can wait and won’t usually matter security‑wise.
Just open App Store → your profile → hit Update next to those priority apps only.
When storage is tight but you still want updates
Instead of deleting random photos blindly:- Settings → General → iPhone Storage.
- Look for huge apps you barely open, offload or delete those first.
- Offload App keeps its icon and documents but removes the app binary so it can reinstall when you tap it. Good way to free space without fully committing to deletion.
Spotting if an update is actually worth it
On the app’s page → Version History → check notes:- If it says vague stuff like “bug fixes & performance improvements” every single time, it’s probably just routine maintenance / SDK updates.
- If it calls out “security fixes” or “patched vulnerability,” prioritize that one.
If you want to be sure you’re not missing anything important, a really simple routine is: once a week, open the App Store, hit your profile, refresh, and update the apps you care about most. Everything else can happily auto‑update whenever iOS feels like doing its job.
Couple of angles that weren’t really covered yet, to help you make sense of what you’re seeing on your iPhone:
1. Figure out what you actually want updates to do
Before tweaking anything, decide your “update style”:
- Hands off: Everything updates when it updates, you don’t care about new features right away.
- Security first: Critical apps stay current, everything else can lag.
- Control freak: You want to know exactly what changes before installing.
Once you know which you are, you can tune your habits instead of fighting iOS.
2. Why some apps look like they never change
Beyond what @sterrenkijker and the other reply already outlined, there are a few extra gotchas:
- Some devs push server‑side changes. The app version stays the same, but the behavior, UI or features quietly change because the app loads stuff from the internet. So “no App Store update” does not always mean “no change.”
- Apple sometimes requires silent re‑signing or compliance updates. That can appear as tiny “bug fix” releases that feel pointless but keep the app from being removed.
If something “never changes” and is also buggy or incompatible with newer iOS features, that’s when I’d worry.
3. Don’t rely only on the “Update All” mentality
I slightly push back on the idea of just hitting update whenever you remember and calling it a day. In practice:
- Some major redesigns are genuinely disruptive. Messaging apps or note apps occasionally ship UI overhauls that slow you down for a while.
- If you depend on a specific app for work, check recent reviews before updating it. A surge of “crashes after update” comments is a sign to wait a version.
So for your most important apps, think: “one minor version behind is fine” unless there is a specific security fix.
4. How to read update notes without overthinking them
When you open an app’s Version History, skim like this:
- Security / privacy keywords: “vulnerability,” “encryption,” “security patch,” “zero‑day,” “privacy controls.” Install sooner.
- Infrastructure buzzwords: “SDK update,” “dependency update,” “framework migration.” Often boring but healthy. OK to install when convenient.
- Risky language: “Complete redesign,” “new experience,” “rebuilt from the ground up.” Maybe hold off if you rely on that app for something crucial.
That way you are not stressed by every little update icon.
5. If you feel overwhelmed by constant update badges
Update fatigue is real. A simple way to stay sane:
- Pick a single weekly time (e.g., Sunday night).
- During that time:
- Update all security‑sensitive apps manually.
- For the rest, clear the list every 2 or 3 weeks.
You are not missing critical security patches for your flashlight app or a wallpaper app. The world will keep turning.
6. Subtle thing about auto‑updates
I slightly disagree with relying on “leave the phone plugged in and unlocked” as your main trigger. It helps, but iOS also looks at:
- How often you use the app
- Network conditions over time
- Whether the app is big and would slow things down
So if something still doesn’t update:
- Open App Store
- Search that particular app
- If it shows an Update button there but not in your Updates list, tap that. It occasionally surfaces stuck updates.
This is different from mass updating and can fix the “one weird app” issue.
7. When an app is clearly abandoned
If Version History and recent reviews show nothing for a long time and it is security‑sensitive:
- Check whether there is an official replacement (same company, newer app).
- Look at alternatives that do the same job but are updated regularly.
- Export data before you switch, if possible.
You are right to worry more about security in this case than about “missing features.”
8. About the product name you mentioned: ‘’
Since you referenced it, a quick, honest breakdown:
Pros of ‘’
- Easy to remember and mention in discussions about updating iPhone apps.
- Can make posts or guides more searchable if people are specifically looking for that phrase.
- Neutral wording that does not lock you into a specific app or vendor.
Cons of ‘’
- The title is extremely generic, so it does not clearly signal a particular tool or concrete solution.
- Not obvious whether it refers to a guide, an app, a service, or just a concept, which can confuse readers.
- Because of that vagueness, it competes poorly with more descriptive phrases when you want very precise help.
Used sparingly and in context, ‘’ fits well inside a broader explanation of how iPhone app updates work, but it should be supported with explicit instructions or examples so people are not guessing what it actually points to.
Bottom line: you are not doing anything “wrong.” Most of what you are seeing is a mix of developer behavior, Apple’s background scheduling, and a little bit of UX weirdness. If you pick a simple routine, read Version History with a security lens, and periodically clean out clearly abandoned apps, you will be in better shape than most users, regardless of whether you follow my approach, @sterrenkijker’s, or a mix of both.
