My Instagram app keeps crashing and some features won’t load, like Stories and direct messages. I’ve tried restarting my phone, clearing cache, and reinstalling the app, but nothing worked. I need advice on what else I can do to troubleshoot this and get Instagram working normally again.
I had something similar on Android a few weeks ago. Stories would spin, DMs failed to load, app crashed every few mins. Here is what helped, step by step.
Check Instagram server status
• Search “Instagram down detector” and see if others report issues.
• If there is a spike, the issue is on their side, not your phone. -
Try another network
• Switch from Wi‑Fi to mobile data, or the other way.
• If it only breaks on one network, restart your router or forget and re‑add the Wi‑Fi on your phone.
• Turn VPN off if you use one. Instagram often behaves weird with some VPN exit nodes. -
Fully wipe app data, not only cache (Android)
• Settings → Apps → Instagram → Storage → Clear data and clear cache.
• This logs you out and resets app settings.
• Then reinstall from Play Store again. -
On iPhone
• Offload the app in Settings → General → iPhone Storage → Instagram → Offload App, then delete leftovers, then reinstall.
• Also go to Settings → General → Transfer or Reset → Reset → Reset Network Settings. You will need to reenter Wi‑Fi passwords. -
Check storage and system updates
• Keep at least 2–3 GB free storage. Low storage often causes crashing.
• Update your OS to the latest stable version.
• Update Instagram to the latest version or try leaving the beta if you joined it. -
Disable battery and data restrictions
• On Android:
– Settings → Apps → Instagram → Battery → set to “Unrestricted” or similar.
– Settings → Apps → Instagram → Mobile data → allow background data and data usage.
• On iPhone: turn off Low Power Mode and check Screen Time restrictions. -
Log in on another device
• Try your account on a different phone or on the web at instagram dot com.
• If Stories and DMs work there, your account is fine and the problem is your device or specific install.
• If it fails on every device, your account might have a soft bug on Instagram’s side. -
Test a second account on your phone
• Create or log in to a different account on the same phone.
• If the second account works, your main account is the issue.
• In that case, report inside the app: Profile → top right menu → Settings and privacy → Help → Report a problem. Add screenshots and mention crashes on Stories and DMs. -
Reinstall an older version (Android only, at your own risk)
• If the issue started right after an update, some users fix it by installing a slightly older APK from a trusted mirror site.
• You need to uninstall the current app first and allow installs from unknown sources.
• This is more technical and has some risk, so only if you know what you are doing. -
As a last resort
• Factory reset only if other apps also misbehave and your whole phone feels unstable.
• Before that, check if Instagram beta is enabled for you in Play Store, and leave the beta if so.
Quick checklist to try first, in this order:
- Test on another device or web.
- Switch network and disable VPN.
- Clear app data and reinstall.
- Remove battery and data restrictions.
- Check storage and OS update.
If you post your phone model, OS version, and Instagram version, people here can narrow it down more.
Couple of extra angles you can try that @chasseurdetoiles didn’t hit directly:
Check if Instagram is actually blocking some activity on your account
Sometimes when they “shadow-limit” features, the app behaves buggy instead of showing a clear warning.- On web, go to Settings → Account Status and also “About” → “Account status / Violations.”
- If you see anything about “temporary limits” or “some features may be unavailable,” that can explain Stories/DM weirdness.
Try using only mobile data for a while, with all “smart network” stuff off
Not just switching to mobile data, but:- Turn off Wi‑Fi completely.
- Disable any “data saver” at system level.
- Let Instagram run for 10–15 minutes and see if Stories/DMs stabilize.
I’ve seen some weird combos of ISP + DNS + Meta services that only show up when the app tries to open realtime features.
Turn off all system‑wide “overlay” and “assistant” stuff
Things that draw over apps or hook into them can make Instagram crash like crazy:- Chat heads / bubble messengers
- Screen recorders
- Floating widgets or gesture apps
- Gaming overlays, FPS counters
Temporarily disable those, then open Instagram and try only Stories and DMs. If it stops crashing, one of those is the culprit.
Log out of all devices, not just your phone
On web:- Settings → Login activity / Devices and log out everywhere.
- Then log back in only on your current phone.
Sometimes a bad session on another phone or tablet causes sync glitches that show up as stuck loading / crashing.
Turn off auto‑sync for other accounts temporarily
If you connected Facebook, Threads, or multiple IG accounts:- Remove the linked accounts, or at least log out of the secondary ones.
- Use just the main account for a day and see if crashes stop.
Multi‑account setups break more often than single ones in my experience.
Change DNS (Android & iOS)
This is one I disagree slightly with @chasseurdetoiles on; it is not always just VPN causing issues. Sometimes your ISP’s DNS is trash with Meta’s endpoints.- Configure “Private DNS” / “DNS over HTTPS” to something like 1.1.1.1 or 8.8.8.8.
- Then fully close and reopen Instagram.
If Stories suddenly load faster, that was it.
Use Instagram Lite or just the browser version for a bit
- If you’re on Android and it’s available where you live, install Instagram Lite and log in there.
- Or on your phone’s browser, open instagram dot com and try Stories/DMs.
If Lite or browser works flawlessly while the main app keeps dying, it’s pretty much a bug with the specific build for your device class.
Profile-specific corruption check
This is weird but I’ve seen it:- Temporarily change your profile: remove bio link, switch back to a regular profile if you’re a business/creator, and remove recently added story highlights.
Some buggy highlight stories or link stickers made my app crash every time I opened DMs, until I removed them on desktop.
Use the in‑app crash reporter immediately after a crash
When it crashes and reopens, don’t just tap around.- Go to Settings & privacy → Help → Report a problem → “Include logs and diagnostics.”
- Write something specific like “Crashes every time I open Stories; device X, OS Y, since version Z.”
Reports sent right after a crash include better logs than random “it’s broken” reports.
If you post your device model, OS version, and whether you’re on any beta (system or Instagram), people can usually spot patterns like “this is a known bug on Android 14 for that phone.” Right now it smells like either a network + DNS combo or some overlay/helper app conflicting with IG.
