I just bought an Apple Pencil and I can’t get it to connect or work properly with my iPad. I’m not sure if I’m missing a step with pairing, charging, or settings. Can someone walk me through the correct way to set up an Apple Pencil so it works smoothly for notes and drawing?
First thing is to check if your iPad even supports your Apple Pencil.
Check compatibility
Open Settings → General → About → Model Name.
Then compare it with this list:Apple Pencil 1st gen works with:
• iPad 6th, 7th, 8th, 9th gen
• iPad Air 3
• iPad mini 5
• iPad Pro 10.5
• iPad Pro 12.9 1st and 2nd gen
• Some newer base iPads use a USB‑C to Pencil adapter for 1st genApple Pencil 2nd gen works with:
• iPad Pro 11 any gen
• iPad Pro 12.9 3rd gen and newer
• iPad Air 4 and newer
• iPad mini 6If those do not line up, it will never pair.
Figure out which Pencil you have
• 1st gen has a cap at the end and a Lightning plug.
• 2nd gen has no cap and attaches magnetically to the side. -
Pair Apple Pencil 1st gen
• Charge the iPad a bit first.
• Plug the Pencil into the iPad Lightning port.
• Wait for the Bluetooth popup. Tap Pair.
• If nothing shows, go to Settings → Bluetooth, turn Bluetooth off, then on, plug Pencil again.
• If you use a USB‑C iPad, use the official USB‑C to Apple Pencil adapter, plug Pencil into adapter, adapter into iPad, then pair. -
Pair Apple Pencil 2nd gen
• Turn on Bluetooth in Settings → Bluetooth.
• Put the flat side of the Pencil on the magnetic edge of the iPad, near the side button area.
• A popup should show. Tap Pair.
• If it does not, remove the Pencil, wait 10 seconds, attach again. -
Check charging
• For 1st gen, after plugging in, check battery:
Settings → Apple Pencil or Settings → Bluetooth → tap the “i” next to Apple Pencil.
• For 2nd gen, attach to the side, a charge overlay should show.
• You can also pull down Control Center and add the Batteries widget to see percentage. -
Fix common pairing issues
• Restart iPad.
• Go to Settings → Bluetooth → tap the “i” next to Apple Pencil → Forget This Device. Then pair again.
• Clean the connector on 1st gen with a dry cloth.
• For 2nd gen, make sure no case blocks the magnetic area. Many cheap cases do that. -
Check settings for writing
• Settings → Apple Pencil.
• Turn on “Only Draw with Apple Pencil” if your fingers keep scrolling instead of drawing.
• Turn on Scribble if you want to write in text fields. -
Test in a simple app
• Open Notes.
• Start a new note.
• Tap the pen icon in the toolbar.
• Draw a few lines. If it works in Notes, the Pencil is fine. If another app ignores it, the app settings are off. -
When it still refuses to work
• Try another iPad if you have access, this helps see if the Pencil is dead.
• If the Pencil was unused for months, the battery can drop to 0 and fail permanently. That happens a lot with 1st gen.
• If no charge shows after 15–20 minutes, and no iPad sees it in Bluetooth, you likely need Apple support or a replacement.
Quick checklist for you
• Correct Pencil for your iPad model
• Bluetooth on
• Pencil charged
• No thick case blocking pairing area or adapter connection
• Paired in Settings, not just attached or plugged in
Run through this in order. Most pairing issues come from wrong Pencil model, dead battery, or a case blocking the magnet or connector.
If you’ve run through most of what @nachtdromer wrote and it’s still being stubborn, here are a few extra angles to try that often get missed:
Rule out the “fake or mismatched” Pencil issue
Not accusing, but there are a lot of third‑party “Apple Pencil” clones.- In Settings → Bluetooth, a real one shows up as “Apple Pencil” (or “Apple Pencil 2”).
- If it only ever shows as something generic like “Stylus” and never brings up the Apple Pencil settings pane in Settings, it’s not going to work like a real Pencil no matter what you do.
Use the Apple Pencil settings page as your truth source
Go to Settings → Apple Pencil.- If this page is missing entirely, one of three things is wrong:
• iPad model does not support Pencil
• iPad is on very old iPadOS
• The Pencil is not being detected at all at a hardware level - If the page appears but says “Not Connected” permanently even while attached/plugged in, that’s usually a bad connector, dead battery, or a third‑party adapter.
Update iPadOS before you pull your hair out
Some older iPads on really outdated iOS / iPadOS are weird about Pencil pairing.- Go to Settings → General → Software Update and install the latest you can.
- Then re‑try pairing. I’ve seen 1st‑gen Pencils suddenly work right after an update when they refused before.
Don’t trust just the popup
Sometimes you do get the “Pair” popup, you tap it, and the Pencil still doesn’t really connect.- After pairing, open Settings → Bluetooth and check that Apple Pencil shows Connected, not just “Paired.”
- If it flips between “Connected” and “Not Connected” while plugged in or attached, that points to bad hardware or a dirty/loose connection.
Test pressure + palm rejection, not just “does it draw”
A half‑paired / half‑supported setup will sometimes draw, but:- No pressure sensitivity
- Crappy palm rejection
- No double‑tap options for 2nd gen
In Notes, try: - Pressing soft vs hard to see if line thickness changes.
- Rest your whole hand on the screen. If your fingers are drawing / selecting instead of the Pencil being prioritized, look at Settings → Apple Pencil → Only Draw with Apple Pencil and turn that on.
Eliminate case and screen protector properly
I know @nachtdromer mentioned cases, but I’d go harsher here:- Pull the iPad completely out of the case.
- If you have a thick glass screen protector and a 2nd‑gen Pencil, sometimes the magnet alignment is just barely off. Press the Pencil a bit firmer to the side and slide it slowly up and down the right edge. Watch if the on‑screen charge animation ever appears.
Deep Bluetooth cleanup
Instead of only forgetting the Pencil:- Turn Bluetooth off.
- Restart the iPad.
- Turn Bluetooth back on.
- Only then attach/plug the Pencil and wait up to 30 seconds.
iPad sometimes hangs on to a glitched Pencil profile and a plain restart does less than this combo.
Check the adapter situation if you have a USB‑C iPad + 1st‑gen Pencil
This part is messy and people skip a detail:- You must use the Apple USB‑C to Apple Pencil adapter for a 1st‑gen Pencil. Generic lightning‑to‑USB‑C cables often only charge and never properly pass the pairing signal.
- Make sure every connection is solid: Pencil → adapter → USB‑C cable (if you’re using one) → iPad. One loose step, no pairing.
Try the “drain and wake” trick on a 2nd‑gen Pencil
If it shows in Bluetooth but won’t really connect:- Leave it off the iPad for a while so it fully discharges.
- Then attach it to the side and leave it there at least 15–20 minutes.
Sometimes they get into a weird low‑power limbo where only a full drain + proper charge wakes them up.
Figure out if the problem is the Pencil or the iPad
If you can borrow:
- Test your Pencil on another compatible iPad.
- Test a known‑working Pencil on your iPad.
If your Pencil fails on multiple iPads, it’s almost certainly dead. Sadly, 1st gens left unused for months do this a lot, the battery just eats itself and never comes back.
If you post your exact iPad model (from Settings → General → About → Model Name) and which Pencil you bought (1st or 2nd gen), plus whether you see the Apple Pencil page in Settings at all, people can tell you in one reply whether it should work or if you’re fighting a combo that will literally never pair.
