I used Cash App Taxes to file this year and I’m confused about a few things in my return, like how certain deductions and credits were calculated and whether I filed correctly. Can someone explain how Cash App Taxes handles common tax situations and what I should double-check to make sure everything is accurate?
Cash App Taxes is decent, but it does a bad job explaining the “why” behind numbers. Here is how it usually handles things and how you can double check if you filed right.
Where to look first
• Download your full PDF return from Cash App Taxes.
• You want: Form 1040, Schedule 1, Schedule A, Schedule C, Schedule D, Schedule E, Schedule SE, Schedule 8812, Schedule EIC, plus any state forms.
• Keep your W‑2s, 1099s, and other docs next to you and match them line by line. -
Standard deduction vs itemizing
Cash App Taxes defaults to whichever gives higher deduction.
2023 standard deduction (for reference):
• Single: 13,850
• MFJ: 27,700
• HOH: 20,800
If your Schedule A is blank or tiny and your 1040 line 12 shows that standard amount, it picked standard.
If Schedule A has mortgage interest, donations, state taxes, etc and 1040 line 12 equals the total from Schedule A, it itemized.
To check:
• Add up your property tax, state income or sales tax, mortgage interest, charity from your records.
• Remember the SALT cap: line 5e on Schedule A cannot go over 10,000 (5,000 MFS).
• If your total on Schedule A is lower than the standard amount, then standard deduction is correct.
- Credits it often auto calculates
a) Child Tax Credit
Look for Schedule 8812.
Rules for 2023:
• Up to 2,000 per qualifying child under 17.
• Up to 1,600 of that part is refundable per child.
What to check:
• Kid must have SSN, live with you over half the year, correct relationship, you claim them as dependent.
• 1040 line 19 shows Child Tax Credit and Credit for Other Dependents.
• Schedule 8812 Part I shows the nonrefundable part, Part II shows the refundable Additional Child Tax Credit on 1040 line 28.
b) Earned Income Credit
Look for Schedule EIC and 1040 line 27.
What to check:
• Earned income amount, filing status, and number of kids match your info.
• If your investment income is over the yearly limit, you should not have EIC.
• Kids on Schedule EIC should match dependents section.
c) Education credits
Look for Form 8863.
• American Opportunity Credit: up to 2,500 per eligible student.
• Lifetime Learning: up to 2,000 per return.
Check:
• 1098‑T info entered correctly.
• Not claiming AOTC for more than 4 years for same student.
- Deductions from income
These show mostly on 1040 Schedule 1.
Common ones:
• Student loan interest, max 2,500, shows on Schedule 1 line 21 and 1040 line 10.
• Educator expenses, up to 300, Schedule 1 line 11.
• HSA contributions, Form 8889 and 1040 Schedule 1 line 13.
Compare each amount on Schedule 1 to source docs.
Example: If your student loan statement says you paid 1,200 in interest, Schedule 1 line 21 should show 1,200, not more.
- Self employment and 1099 income
Look for: Schedule C, Schedule SE.
• Gross income on Schedule C line 1 should match all your 1099‑NEC/1099‑K plus any extra you typed in.
• Expenses should be things you entered, nothing random.
• Net profit on Schedule C line 31 flows to Schedule 1 line 3 and to Schedule SE.
Self employment tax:
• Shows on Schedule SE and 1040 line 23.
• Half of it gets deducted on 1040 Schedule 1 line 15.
If your gig income looks way off, check each 1099 input in the software.
- Withholding and refunds
Compare:
• W‑2 box 2 to 1040 line 25a.
• 1099‑R withholding to 1040 line 25b.
• Any 1099‑INT/1099‑DIV/1099‑B/1099‑G withholding to 1040 line 25c.
Total tax: 1040 line 24.
Total payments: 1040 line 33.
If line 33 is bigger than 24, refund on line 34.
If line 24 is bigger than 33, tax due on line 37.
If the refund looks strange, 9 times out of 10 something is off in withholding or a credit.
Common spots where Cash App Taxes confuses people
• It sometimes auto selects standard deduction even when users think they itemized, because state and local taxes get capped.
• It prompts for EIC and CTC but does not explain phaseouts clearly. Higher income cuts those credits down.
• For 1099‑K and 1099‑NEC income, it expects you to enter expenses. If you skipped that, your income is inflated and tax looks painful. -
How to see if you filed “correctly”
Quick checklist:
• All income forms accounted for, nothing missing, nothing duplicated.
• Filing status matches your real situation.
• Dependents correct, no one claimed twice across households.
• Standard vs itemized makes sense when you do a quick manual total.
• Credits match your dependents, income level, and school info.
• Bank info for refund correct.
If you want feedback on specific numbers, post:
• Your filing status.
• Basic income types (W‑2, self employment, unemployment, etc).
• What credits you see on 1040 lines 19, 27, 28.
• Whether you used standard or itemized.
Scrub any personal data first. Then people here can tell you if the numbers look normal or if something likely went wrong in Cash App Taxes inputs.
Cash App Taxes is kinda like a black box: you feed numbers in, it spits a refund out, and explains almost nothing. @vrijheidsvogel covered the form-by-form check really well, so I’ll hit this from a different angle: how the software thinks and the spots where it silently “decides” things for you.
- How it decides deductions & credits
Cash App isn’t really “choosing” in a smart way; it just runs the IRS rules in the background:
- If something is “above the line” (like student loan interest, HSA, SE tax deduction), it reduces AGI.
- Then it compares standard deduction vs Schedule A and uses the larger.
- After that, it layers on nonrefundable credits (can only reduce tax to zero) and then refundable credits (can create or increase a refund).
If you want to sanity check the logic, ignore the software for a minute:
- Compute AGI: sum of all income minus adjustments.
- Use the correct standard deduction for your filing status.
- Taxable income = AGI minus deduction.
- Use the IRS tax tables for your bracket.
Then: does your “tax before credits” roughly match 1040 line 16? If yes, Cash App probably followed the rules; your confusion is more about why the IRS rules are awful than about the app messing up.
- Why some credits are smaller than you expect
This is where people think Cash App “messed up” when it really just didn’t explain phaseouts:
Child Tax Credit:
Above certain income, it shrinks. So if you got “less than 2k per kid” and your income is higher than past years, the software is following the law, not shorting you. Check your AGI versus last year. -
Earned Income Credit:
The EIC curve is weird:- Too low income: small credit.
- “Middle” income: higher credit.
- Too high income: phased out.
If your earned income changed a lot compared to last year, your refund can change a ton even if nothing else did. That freaks people out, but Cash App is just plugging you into that curve.
- Why your refund can move a lot even if the numbers “look similar”
Couple things that spike or drop your refund that Cash App does not flag clearly:
- Extra 1099 side income with no expenses: balloons your SE tax and wipes out credits.
- Losing a dependent, or a kid aging out of CTC/EIC categories.
- Change in withholding at work (W2 box 2 lower than last year).
If your refund changed a ton year to year, compare:
- Dependents section
- Total federal withholding
- Total self employment income
Not the deductions first. The refund story is mostly about those three.
- Places where I do think Cash App can nudge you the wrong way
I don’t 100% agree with @vrijheidsvogel that it is just “decent but confusing.” A couple spots it can quietly push you into weird territory:
Filing status prompts:
It is too casual about Head of Household. A lot of people click HOH because it sounds right, when they do not actually qualify. That can inflate your refund and then the IRS letter shows up later. Double check HOH rules on irs.gov, not in-app tooltips. -
Business expenses:
It lets you leave them blank without making it clear you are overpaying. If you got 1099-NEC/1099-K and had any legit costs (mileage, supplies, fees, etc.) and you did not enter them, your tax is probably too high. -
State returns:
Sometimes state itemized vs standard does not match federal. Cash App does it but barely explains it. Your state refund can look random if you assume the same deduction method as federal.
- How to tell if you “filed correctly” without redoing the whole return
Quick mental triage that does not repeat all the form-by-form stuff:
Step 1: Does every document appear somewhere?
Count your W2s, 1099s, etc. That count should match what you entered. Missing income is worse than math errors. -
Step 2: Are your life facts aligned with the return?
- Filing status actually correct for your situation.
- Number of dependents matches reality.
- Every child you claim lived with you long enough and was not claimed by someone else.
Step 3: Does the story match last year?
- If your income and dependents barely changed but your refund swung by thousands, then something is likely off.
- If income went up and credits went down, that is probably legit phaseout behavior.
Step 4: Check 3 numbers only:
- 1040 line 15 (Taxable income)
- 1040 line 24 (Total tax)
- 1040 line 33 (Total payments)
If taxable income looks about what you’d expect from your job(s), and total tax is in the same ballpark as what IRS tables say for that income, then Cash App’s math is fine. Refund is just “payments minus tax.”
If you want people here to sanity check it, you can post (scrub personal data):
- Filing status
- AGI, taxable income
- Main income types (W2 only? any 1099?)
- Number of dependents and which credits show on lines 19, 27, 28
and we can usually spot “yep, that’s just phaseouts” vs “nope, something is actually wrong” pretty fast.
Skip the “how to read every line of every form” angle for a second and look at why Cash App Taxes made the choices it did. Think of it like debugging the logic instead of the math.
1. What Cash App Taxes is actually optimizing
Contrary to how it feels, it is not trying to “get you the biggest refund.” It is just:
- Computing your tax based on IRS rules
- Comparing deduction options
- Applying credits
Your refund is mostly:
Total payments (withholding & credits) minus total tax
So to see if you filed “correctly,” focus on whether the inputs and IRS rules are right, not whether the final refund number “feels right.”
I slightly disagree with @sognonotturno and @vrijheidsvogel on one thing: you do not always need to dissect every schedule to sanity check. You can often answer “did this file correctly?” with just a small set of high level comparisons.
2. Fast logic checks that catch a lot of issues
Use your PDF, but instead of going line by line, ask:
A. Does your “tax story” make sense compared to last year?
Look at these four numbers only:
- AGI (1040 line 11)
- Taxable income (line 15)
- Total tax (line 24)
- Total payments (line 33)
Then compare to last year:
- If income is similar, dependents are the same, and withholding similar, your total tax and refund should be in the same ballpark.
- If your income jumped a lot, expect:
- Higher total tax
- Smaller child-related credits or EIC
- Possibly a lower refund even if withholding rose a bit
If the swings here are wild while your life barely changed, that is a red flag that something in Cash App Taxes got mis-entered.
3. How to decode confusing pieces without redoing everything
A. “Why is my Child Tax Credit / EIC smaller?”
Instead of re-calculating everything, do this:
- Check AGI vs last year
- Ask: did your income move into a higher range?
- Kids:
- Any child turning 17 affects Child Tax Credit
- EIC rules change at different ages & income ranges
If your income went up and the credits shrank, that is probably phaseout behavior, not a Cash App bug. This matches what @vrijheidsvogel said, but I would treat this as a quick first filter before digging deeply into Schedule 8812 and Schedule EIC.
B. “Did it pick the right deduction method?”
You do not need to re-add every itemized expense:
- Look at 1040 line 12
- Compare that number to the standard deduction for your filing status
- If line 12 equals the standard amount, Cash App Taxes used standard
- Ask: “Could my mortgage interest + property tax + charity reasonably beat that?”
If the answer is “absolutely not,” the choice was correct even if Schedule A is confusing. Only if you know you have very large itemizable expenses do you need to go line by line the way @sognonotturno outlined.
4. Where Cash App Taxes quietly trips people
The part I think both others underplayed:
Head of Household
The prompt flow in Cash App Taxes practically invites people to pick HOH when they do not qualify. Wrong filing status can:- Inflate your refund
- Cause an IRS letter later
Double check HOH directly from IRS rules, not from any brief in-app help text.
Side income treated as pure profit
If you had:- 1099 NEC
- 1099 K
- “Other income” from selling stuff / freelance
and you did not enter expenses, the software assumes 100% profit. That can:
- Raise self employment tax
- Push you into higher brackets
- Shrink your credits
This is one of the most common ways people think Cash App “robbed” them, when really they just skipped the expense section.
State returns that do not mirror federal
Cash App Taxes can choose standard vs itemized differently for state than for federal with almost no explanation. Your state refund can look “random” if you assume both are using the same method. They are often not.
5. Answering “did I file correctly?” in 4 yes/no checks
Instead of repeating the detailed form checklist others gave, ask yourself:
Did every document get entered exactly once?
- Count W2s, 1099s, etc.
- Same count as what you see reflected in the return? No accidental double entries?
Is your status & dependents story true to reality?
- Filing status matches your living & marital situation
- Every child you claimed truly qualifies according to IRS tests
- No shared dependents with another household unless you know the tiebreaker rules
Is your taxable income roughly what you expect from your job plus known side work?
- If you make, say, 50k at work and 5k in side income, taxable income in the 40–50k range after deduction is normal
- If taxable income looks like your gross pay with no deduction effect, something is off
Is total tax in line with IRS tables for your income?
- For middle incomes, total federal tax being around 10–22 percent of taxable income is common
- If it is wildly off, either credits are huge or something fundamental is wrong
If those four checks pass, odds are high that Cash App Taxes filed you correctly, even if the internal layouts and schedules are confusing.
6. Pros and cons of using Cash App Taxes for this
Since you mentioned confusion, here is a quick view of the product itself:
Pros of Cash App Taxes
- $0 pricing for federal & many states
- Handles most common income types: W2, basic 1099, standard investments
- Decent for straightforward credit situations like simple Child Tax Credit or basic EIC
- Integrates with Cash App payout, which some people like
Cons of Cash App Taxes
- Very limited explanations of why credits or deductions change
- Weak guidance on complex things like multi-state income, rental properties or tricky HOH situations
- Easy to leave business expenses blank and overpay
- State returns feel like an afterthought for more complicated state rules
- Not as strong at “teaching” you what is happening compared to competitors like some of the bigger paid platforms
Both @sognonotturno and @vrijheidsvogel posted solid deep dives already, but they lean more into traditional form-walking. Helpful if you like detail. If you just want to know “did this black box behave according to IRS logic,” the higher level cross-checks above will usually get you there with less effort.
If you want, you can post (with all personal info removed):
- Filing status
- AGI & taxable income
- Main income types (W2, 1099, self employment)
- Lines 19, 27, 28 from Form 1040
and people here can generally spot whether Cash App Taxes handled your credits and deductions in a way that matches the rules.
