My Bambu Lab A1 Mini 3D printer was working fine, but now I’m running into problems and can’t figure out what changed. I need help troubleshooting the issue so I can get back to printing without wasting more time and filament.
Start with the easy stuff. Most A1 Mini problems fall into 5 buckets.
Filament path
Unload it. Cut the end clean. Check the PTFE tube for kinks. Make sure the spool spins free. Wet filament causes stringing, popping, weak layers. Dry PLA at 45 to 55 C for 4 to 6 hours. -
Nozzle and hotend
Do a cold pull. If flow looks weak, swap the nozzle. Partial clogs ruin first layer and underextrude the rest. On Bambu machines, one tiny clog wrecks a print fast. -
Bed and first layer
Wash the plate with dish soap and hot water. No hand soap. No alcohol first if grease is heavy. Re-run full calibration. Watch layer 1. If lines look round, nozzle is too high. If it drags and smears, too low. -
Belts and motion
Check X and Y belt tension. Loose belts cause ringing and layer shifts. Look for junk on the rails. Move the toolhead by hand with power off. It should feel smooth, not gritty or sticky. -
Slicer and settings
If it worked before, load a known good old project and print it unchanged. If the old file fails too, the issue is hardware or filament. If the old file prints fine, your new slicer profile is the problem. Reset filament profile, temps, speed, and cooling.
Fast test plan:
Print a 20 mm cube.
Then print first-layer test.
Then print a temp tower.
Post 3 things if you want better help:
- Clear pic of first layer
- Pic of failed print
- Filament type, nozzle temp, bed temp, speed
If you hear clicking from the extruder, start with a clog or tangled spool. If adhesion is the issue, 8 times out of 10 it is a dirty plate or bad Z offset. If layers shift, look at belts or somthing blocking motion.
If it suddenly went from fine to cursed, I’d also look at the stuff people skip because it’s “probably not that.”
First, firmware and slicer weirdness. If Bambu Studio updated recently, try re-slicing with an older known-good profile, or even print one of the printer’s built-in calibration/test files if you have one. I’ve seen odd behavior come from profile drift more than actual hardware.
Second, check the extruder gears directly. Not just for a clog. Tiny filament dust buildup in the drive gears can make feeding inconsistent without being a total jam. That gives you those annoying “it kinda prints, but badly” failures.
Third, power and connectors. Reseat the hotend/nozzle assembly and make sure the toolhead connector is fully seated. Intermittent temp readings or heater issues can look like random underextrusion. Super annyoing, and easy to miss.
I’d also not obsess over belts first unless you’re getting obvious shifting. @espritlibre covered the mechanical basics well, but if your issue is more like rough surfaces, random gaps, or temp swings, I’d lean nozzle seating, fan behavior, or a flaky connection before belt tension.
One more thing: watch the part cooling fan during a print. If it’s not spinning right, PLA can suddenly turn into a stringy mess and make you think the whole printer died.
If you can, post:
- what exactly changed in the failure
- pics
- whether it fails on every model or just one
- any error msges on the screen
That usually narrows it down fast.
I’d go at it from the “what changed outside the printer” angle.
If the Bambu Lab A1 Mini 3D printer was fine and then suddenly wasn’t, humidity is high on my suspect list. A spool that printed great last week can start causing popping, weak layer bonding, fuzzy walls, and random underextrusion after sitting out. Before tearing into the machine, try a brand-new or freshly dried spool and reprint the same file.
I also slightly disagree with chasing hardware first unless the failure is dramatic. A lot of “printer broke” cases are actually:
- wet filament
- wrong filament profile selected
- accidental nozzle size mismatch in slicer vs actual nozzle
- first layer offset drift after moving the printer
Another overlooked one: wash the build plate properly. Dish soap, warm water, no hand-touching after. The A1 Mini can look mechanically fine but fail because adhesion got weird, then everything downstream looks broken.
Quick isolation test:
- Print a tiny single-wall cube
- Then print a first-layer test
- Then try a known-good old gcode
That tells you whether it’s extrusion, adhesion, or slicer-related.
Pros for the Bambu Lab A1 Mini 3D printer: fast, easy calibration, great quality when dialed.
Cons: small changes in filament condition or profiles can create surprisingly messy failures.
@espritlibre is right to ask for photos. Also post the filament type, nozzle size, and whether failures start on layer 1 or later.
