Need help with my HP OfficeJet Pro 9125e all-in-one printer
My HP OfficeJet Pro 9125e all-in-one printer suddenly stopped printing and now it keeps showing errors when I try to use it. I’ve checked the basics, but I still can’t get it working for printing, scanning, or copying. I need help figuring out what caused this and how to fix it fast.
Start with a full reset. This model gets stuck hard when the print service crashes.
  1. Turn the printer off.
  2. Unplug power from the wall for 60 seconds.
  3. Plug it back in direct to the wall, not a surge strip.
  4. Turn it on and wait until the home screen is idle.
Then check the screen for the exact error code. HP errors matter. “Printer failure” is different from “carriage jam” or “ink system error”.
Next steps I’d do:
  1. Remove all ink cartridges.
  2. Check for jammed paper, even tiny scraps in the rear path.
  3. Open the cartridge area and make sure the carriage moves freely. Gently. Don’t force it.
  4. Reinstall cartridges.
After that, print a report from the printer screen, not from your PC. If it won’t print a self-test, the issue is in the printer, not your computer.
If scanning and copying also fail, that points to firmware or hardware. Try this:
  1. On the printer, open Settings, Printer Maintenance, Restore, Restore Factory Defaults.
  2. Reconnect Wi-Fi.
  3. Run HP Smart and check for firmware updates.
If HP Smart still throws errors, remove the printer from HP Smart and from Windows Printers, then reinstall it using the full HP driver package. Don’t use the old entry. It gets buggy.
One more thing, if the scanner light never moves and copy fails too, the scanner assembly or main board might be toast. At that point, service or warranty is the next step.
Post the exact error text if you want a more narow fix.
If print, scan, and copy all died at once, I’d stop chasing the PC side for a minute and check whether the printer is actually booting cleanly into a ready state. @suenodelbosque covered the reset/factory-default route, but I’m not totally sold on jumping to factory reset first unless the screen is usable and stable. Sometimes that just adds setup pain without telling you what failed.
A few things I’d check that are different:
  • Try copying with the lid up and watch the scanner bar. If it jerks, buzzes, or doesn’t light at all, that’s a hardware clue.
  • Listen on startup. Grinding/clicking usually means carriage or paper path sensor trouble, even if no jam is visible.
  • Disconnect USB if attached, and temporarily turn off Wi-Fi during testing. Weird print queue loops can keep these HPs acting dumb.
  • In Windows, clear the print spooler completely. A stuck job can keep throwing “printer error” forever.
  • Check the HP Embedded Web Server if the printer still has an IP address. Open the IP in a browser and look for supply/system status there. Sometimes it shows more detail than the front panel.
  • If the touchscreen is laggy or freezing, suspect firmware corruption or mainboard issues more than ink.
Also, if it fails to make a copy with no computer involved, that’s the big tell. At that point it’s probly not a driver problem. If you can post the exact wording of the error, that narrows it down fast.
