Recover Deleted Videos From SD Card After Pressing Delete By Mistake?
I accidentally pressed delete and removed important videos from my SD card before backing them up. I stopped using the card right away because I’m worried the files could be overwritten. I need help figuring out the best way to recover deleted videos from an SD card and what recovery software or steps actually work.
I lost a clip once from an SD card after clearing space too fast. The part that mattered was what I did in the next minute. If you deleted a video, your best move is to stop touching the card right away.
What usually happens is simple. The camera or card does not wipe the video data on the spot. It marks the space as free. Your old footage often sits there until new recordings land on top of it. If you keep shooting, your odds drop fast.
First thing, leave the card alone
Do these first:
  1. Stop recording.
  2. Do not shoot photos either.
  3. Do not format the card.
  4. Pull it out of the camera.
I keep seeing people lose recoverable footage because they kept using the card for 'one more test clip.' Bad move. Once sectors get overwritten, software has less to work with.
Check if your computer still sees the card
Put the card in a reader and connect it to your computer.
If Windows says the card needs formatting, or shows it as RAW, do not panic yet. Recovery apps often still read the device and scan the raw data. The key part is detection. If the computer sees the storage device, you still have a path.
If the card does not show up at all, I would stop there. Unplugging and replugging ten times rarely fixes anything useful. At that point, a recovery shop starts making more sense.
Start with software
For deleted video files, I would begin with Disk Drill.
The reason is its Advanced Camera Recovery mode. A lot of cameras do not write long videos in one neat block. They scatter pieces of the file across the card. I saw this with action cams and drones in particualr. A standard scan might find fragments but fail to rebuild a playable video.
This mode was made for fragmented camera footage. It tries to piece the video back together in a way ordinary file recovery often misses. Useful if your clips came from GoPro, DJI, Sony, Canon, Nikon, Fujifilm, Insta360, dashcams, and similar gear.
Basic recovery flow
  1. Connect the card with a card reader.
  2. Open Disk Drill.
  3. Pick the memory card.
  4. Select Advanced Camera Recovery.
  5. Run the scan.
  6. Preview what it finds.
  7. Save recovered videos to another drive.
Do not restore files back onto the same card. I did this years ago with photos. It went poorly.
If the first tool misses stuff, try another one
No single recovery app gets everything. I have had one tool miss clips and another pull them up on the same card.
  1. PhotoRec. Free, solid, ugly. It often recovers files without original names or folder layout.
  2. R-Studio. Good deep scan options. Takes a bit to learn, and the interface is not friendly.
  3. DiskGenius. Worth a shot if the card has file system damage or partition weirdness.
Different tools look at the card in different ways. A second scan sometimes finds more, or finds a cleaner version of the same video.
If the footage matters, make an image first
If this is wedding footage, paid client work, family stuff, or anything you do not want to gamble with, create a full disk image before recovery.
A byte-for-byte image gives you a frozen copy of the card in its current state. Then you scan the copy instead of hammering the original card over and over. This is one of the few habits from recovery pros that makes immediate sense when you try it yourself.
Know when to stop doing it yourself
Software tends to work best for logical problems like these:
  1. Deleted videos.
  2. Accidental formatting.
  3. File system corruption.
  4. RAW card state.
  5. Missing files on a card that still seems healthy.
I would look at a recovery service instead if you notice any of this:
  1. The card is bent, cracked, or otherwise damaged.
  2. It gets hot for no good reason.
  3. Your computer does not detect it at all.
  4. The card disconnects during scans.
  5. The footage matters enough that a failed DIY attempt would hurt.
Once hardware trouble shows up, home recovery gets riskier. Pushing through scan after scan on a failing card sometimes makes the situation worse.
Short version. Stop using the card, check if the computer detects it, scan it with recovery software, save results somewhere else, and do not keep experimenting if the card looks physically unstable. That order gave me the best results when I had to deal with this stuff.
You did the most important part right. You stopped using the SD card.
I agree with @mikeappsreviewer on that. I differ on one point though. If the card shows RAW or asks to format, I would not rush into trying multiple scans on the original card first. I’d make an image of the card before anything else if the videos matter. One bad read on a flaky card and things get messier.
My order would be:
  1. Lock the SD card, if it has the tiny write switch.
  2. Use a decent card reader, not the camera over USB.
  3. Check SMART is not a thing on most SD cards, so watch for slow reads, disconnects, or I/O errors.
  4. Clone the card to an image file with something stable.
  5. Run recovery on the image, not the card.
For cloning, on Windows I’d use USB Image Tool or HDD Raw Copy Tool. On Mac or Linux, ddrescue is the safer pick if reads are failing. This matters more than people think. If your card has weak sectors, repeated scans chew up time and stress it.
For recovery, Disk Drill is a solid first pick for deleted videos from SD cards, esp if the footage came from a camera, drone, or action cam. If it finds multiple versions of the same clip, recover all of them to your computer. Check filesize, duration, and playback in VLC. Bigger file does not always mean better file. I learned that the annoyng way.
One more thing people skip. If the recovered video will not play, try repair tools for damaged MP4 or MOV headers. Deletion recovery and video repair are two diffrent steps. A file recovered at 90 percent still might need repair before it opens.
If the card disconnects, gets hot, or vanishes from Disk Management, stop DIY. That points more toward hardware failure than simple deletion.
Also, this short clip explains memory card video recovery in plain english:
watch this Instagram Reel on recovering deleted videos from a memory card
One thing I’d add to what @mikeappsreviewer and @techchizkid said: check the card in the camera itself first, but only for playback, not recording or formatting. Some cameras do a weird “soft delete” / database update thing and a clip can still appear in playback even when the card looks wrong on a PC. If it’s there, copy it off with the camera’s export option if available. If not, then move to a reader.
I also would not obsess over file names. For deleted SD card video recovery, names/folders are often toast, but the video itself can still be fine. Prioritize recoverability over neatness.
Disk Drill makes sense here, esp for camera footage, but I’d sort results by file type + size and recover the biggest likely matches first. Then test in VLC. If the clip is found but won’t open, that does not always mean total failure. Sometimes the video data is there and only the container/header is busted.
Also, small but important: if this was shot on exFAT and the delete happened in-camera, there’s a chance the file system metadata got altered in a way that makes “undelete” weaker than signature-based carving. So don’t panic if the first pass looks messy.
For more practical SD card deleted video recovery tips and user experiences, check this real-world deleted video recovery discussion.
If the card starts acting slow, throws read errors, or mounts/unmounts randomly, stop messing with it. That’s the point where DIY goes from “maybe recoverable” to “whoops I made it worse.” Kinda sucks, but true.
