I just started using my iPad more for work and school, and I’m overwhelmed by all the note‑taking apps out there (GoodNotes, Notability, OneNote, Apple Notes, etc.). I need something that handles Apple Pencil handwriting really well, syncs reliably across devices, and makes it easy to organize class notes and meeting minutes. I’d love real‑world feedback on which app you’ve found best and why, especially for long study sessions and daily productivity.
Short version. If Apple Pencil handwriting is your main thing, start with GoodNotes or Notability. If typed notes and cross‑platform matter more, look at OneNote. If you want simple and free, Apple Notes is fine.
Here is the more detailed breakdown.
GoodNotes 6
• Handwriting: Best handwriting feel out of the bunch. Low latency, good palm rejection, pencil pressure works well.
• Organization: Notebooks, folders, custom covers. Easy to keep “Work” and “School” separate.
• Annotation: Great for PDFs. Import lecture slides, mark them up, export as PDF.
• Search: Handwriting search works well for neat to medium‑messy writing.
• Math / diagrams: Lasso tool, shape snapping, color presets. Good for equations and quick sketches.
• Pricing: One‑time or subscription. The free tier is limited to a few notebooks.
Fit for you if you do a lot of handwritten notes, diagrams, and PDF annotations for class and meetings.
Notability
• Handwriting: Slightly less “paper‑like” than GoodNotes, still solid.
• Audio recording: Killer feature. Records audio while you write. Tap a word later and it jumps to that moment in the recording. Great for lectures or meetings.
• Organization: Subjects and dividers. Less flexible than GoodNotes folders but works.
• PDF: Strong annotation tools, highlight and write on slides fast.
• Search: Handwriting search also decent.
• Pricing: Subscription now. Free tier is capped for edits and storage.
Fit for you if you attend lectures or meetings where audio is important and you want synced notes plus recording.
Apple Notes
• Handwriting: Supported, but the tools feel basic. No full notebook system.
• Sync: iCloud sync is solid. Works on every Apple device.
• Search: Text search is good, handwriting search is meh.
• Use case: Quick notes, checklists, short sketches.
Fit for you if you want zero setup and light handwriting.
OneNote
• Handwriting: Acceptable but not as pleasant as GoodNotes or Notability on iPad.
• Structure: Free‑form pages. Infinite canvas style. Sections and notebooks.
• Cross‑platform: Best option if you use Windows or Android along with iPad.
• Typing: Great for mixed typed notes, pasted content, and some handwriting.
• Price: Included with Microsoft 365, or free with some limits.
Fit for you if you want strong typed notes and cross‑platform sync, with handwriting as a bonus.
Practical suggestion for your situation
Work and school, Apple Pencil heavy:
- Install GoodNotes and Notability free versions. Give each 3 days of real use in class or at work.
- In GoodNotes
• Take lecture or meeting notes by importing the PDF or slides.
• Try handwriting search on your notes after a week. - In Notability
• Record one lecture or meeting while you write.
• Later, tap your handwriting to jump in the audio, see if that helps you review. - Compare
• Does audio help you, or do you never replay it.
• Do you prefer the “notebook” feel of GoodNotes or the single scrolling notes of Notability.
• Which one feels faster to open and use in a rush.
If you work a lot on Windows or need typed notes that sync everywhere, add OneNote to that test and see if you tolerate weaker handwriting tools in exchange for cross‑platform support.
Most students I see end up like this
• Heavy handwritten notes and PDFs only on iPad: GoodNotes.
• Lecture heavy classes with lots of talking: Notability.
• Mixed devices and typed docs: OneNote plus occasional Apple Notes for quick stuff.
If Apple Pencil is your main thing, the “best” app is really about workflow, not just handwriting feel. I’ll push back a tiny bit on @sternenwanderer here: I don’t think GoodNotes vs Notability is just “handwriting vs audio.” It’s more like “structured notebook brain vs stream‑of‑consciousness brain.”
Here’s how I’d split it, assuming work + school and lots of handwriting:
1. GoodNotes 6 if you like structure and visual order
Use this if you:
- Think in “notebooks” and separate subjects clearly
- Like flipping pages and having a sense of “where” something is
- Live in PDFs (lecture slides, reports, research papers) and like clean exports
Where it really wins:
- Page templates & organization are very nice for course-by-course or project-by-project setups
- Reviewing feels like going through a physical notebook instead of scrolling a giant blob
- Finals / big meetings: you can keep a dedicated notebook per class or client, which is nicer than having hundreds of long notes
Where it can annoy:
- If you’re in a rush and just want to dump something quick, the “create notebook, pick template” flow can feel a bit heavy
- Audio is an afterthought compared to Notability
2. Notability if your life is messy and fast
Use this if you:
- Are constantly bouncing between classes/meetings with no prep time
- Want to slam “new note,” write, and sort it out later
- Actually re‑listen to lectures or meetings
Real advantage over GoodNotes isn’t just audio:
- One long scrolling note per session is amazing for fast, chaotic lectures
- The handwriting + audio link helps if you zone out or if the speaker talks faster than you can write
- Quick capture is better. You’re less likely to say “eh, I’ll write this later” and then forget
Where it loses:
- Less “pretty notebook” feel
- If you never listen to recordings, the subscription can feel pointless
3. Apple Notes is your scratchpad, not your main system
I partly disagree with using it as your primary school/work notebook if handwriting matters:
- Handwriting tools are basic, and long-term studying from Apple Notes is kind of awful
- Great as an inbox: quick idea, short sketch, phone number in a call
- Later, you move the important stuff to GoodNotes / Notability / OneNote
Think of it like a sticky note, not a binder.
4. OneNote if your job or school life touches Windows a lot
This is where @sternenwanderer is right on the money:
- Cross‑platform and typed notes are the reason to use it
- Handwriting is “fine,” not great
- If you write a lot with a keyboard and just occasionally circle or annotate with Pencil, it makes sense
I’d only pick this as the main iPad app if:
- You’re already deep in Microsoft 365
- You need your notes on a work PC constantly
- Your handwriting is secondary to typing, search, and integration
5. What I’d actually do in your shoes
Since you’re doing both work and school, I’d build a 2‑app setup instead of forcing everything into one:
Primary handwritten notes app:
- If you love neat, separated subjects → GoodNotes
- If your classes/meetings are fast and talky → Notability
Quick capture / backup app:
- Apple Notes for random thoughts, quick sketches, to‑do lists
- Or OneNote if your job is Microsoft heavy and you need stuff on a PC
One more small, non‑obvious point:
Try taking a full week of notes in each app without switching. The first 30 mins usually feels “wow, this is nice,” but the truth comes out when:
- You need to find something from 5 days ago
- You’re cramming / prepping for a big meeting and need to flip through a lot of material
- You have 20+ separate notes and the app either feels organized or like a landfill
If I had to give you a blunt default without seeing your exact workflow:
- Mostly handwritten notes, PDFs, and studying on the iPad: GoodNotes 6
- Mostly live lectures/meetings where people talk fast and you don’t catch everything: Notability
- Mixed devices and typed docs: OneNote as main, Apple Notes as scratchpad
Try not to overthink it too much. Pick one of GoodNotes or Notability, commit for a couple weeks, and only switch if it’s actively getting in your way.
